Author Topic: power steering rack  (Read 1160 times)
Offline leeroy20vt
  • h reg mk2 gti
power steering rack
« on: 27 July 2009, 21:58 »
how do u get it off the car its all undone and loose just the bolts the that go thru sub frame wont come out cant work out how there held in any idea or do i need to drop the subframe
any ideas cheers
Offline Ben Lessani
Re: power steering rack
« Reply #1 on: 27 July 2009, 22:01 »
The bolts in the subframe are captive - they won't come out, they are effectively studs.
If the engine is still in, you need to drop the subframe.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 27 July 2009, 22:13 »
engine still in so will do that tom cheers m8 thought as much lol
Offline Mew
« Reply #3 on: 27 July 2009, 22:15 »
If you mean the 4 bolts that secure the steering rack, i found a smack from the top releases them. They have a spline that stops them from just dropping out of the subframe when the nut is removed
Offline leeroy20vt
  • h reg mk2 gti
« Reply #4 on: 27 July 2009, 23:12 »
yer there the 1s cant really get anythink in there to hit em tho believe me ive tried lol
think it may just be as as easy to drop subframe as all the hoses are still connected and dont want to brake them  :undecided:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #5 on: 28 July 2009, 17:33 »
got it out cheers for the help peeps had to drop the subframe as far as it would go thanks to the pipes being siezed on
next venture take non power rack off and replace with a power 1 o what joy lol
