Author Topic: mk2 16v  (Read 5178 times)
kniterider
Re: mk2 16v
« Reply #20 on: 02 September 2004, 16:10 »
sounds like the 16v maybe has the common 'idle stabilisation valve' problem???? or similar, its deffo down to fueling. I admit Mr 6' was helpful on with alot of diagonsis problems, but as said earlier there are others that have dared to venture under a bonnet of a vw!!!! Gambit, i find is helpfull with mk2 16v probs, give him a shout.
oh yeah as regards to under bonnet work, ermm therell be some stage by stage pics of my 16v stem seal repair soon, and also my mk4 20v head is coming off again!!!!! (still running at mo but orig head going back on!!)
Gaz :o
Offline Gambit
Re: mk2 16v
« Reply #21 on: 03 September 2004, 11:28 »
when you say it turns off, do u mean it just die's?
or do the gradually rev's drop off after a certain length of time until it stalls.
if you gimme a better description of the prob i should be able to give you a better answer.
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: mk2 16v
« Reply #22 on: 06 September 2004, 15:03 »
he reved it then as soon as he took foot off accelerator
the revs dropped then it juddered n died
but he told me sometimes it will run great
but i dunno how
Offline Gambit
Re: mk2 16v
« Reply #23 on: 06 September 2004, 15:17 »
tbh its sounds like it just needs properly setup, as this is the cause of most dodgy idle/bad tempered 16v's!!
here's how to set it up
http://www.btinternet.com/~gvk_motorsport/16valvestall.html
u may have trouble getting an allen key long enough to adjust the CO%
alternativly take it to a local 3rd party specialist if you dont feel confident enough to do it yourself. should only cost ?25 to tuneup
