Author Topic: 16valve conversion, whats it worth?  (Read 3781 times)
Offline mr ritz
« on: 27 July 2009, 12:26 »
Hi all,
Am just trying to assess what this is worth before i decide wether to break it and sell the bits separately?
I've got....
16v kr engine, freshly overhauled and rebuilt. (with brand new 0 miles clutch)
gearbox for above (mk1 gti output shafts fitted for easy mk1 driveshaft usage)
16v exhaust manifold (homemade but solid, fits to standard mk1 system)
16v ignition loom
16v ignition ecu
twin dellorto 40 carbs
throttle linkage for above
inlet manifold for carbs
fuel pump for carbs
fuel filter/regulator for carbs
all engine ancillaries
I'm sure theres bits and bobs i've forgotton, but its basically everything needed for a mk1 twin 40 16valve conversion.
Any ideas?
Thanks.
Offline Lee_dub
Re: 16valve conversion, whats it worth?
« Reply #1 on: 06 August 2009, 23:37 »
Hi mate, I would say the following....
Engine with all ancills - £120
gearbox -£50
inlet mani + carbs and linkage £100
ignition loom + ECU £20
pump and regulator - £30
homemade exhaust manni - £worthless
job lot - £250
thats my opinion mate, good luck with the sale!
Black mk1 2.0 16V - woop
Offline mk1tt16v
« Reply #2 on: 07 August 2009, 07:44 »
you will get a lot more than 100 for the carbs and mani
Offline Lee_dub
« Reply #3 on: 09 August 2009, 15:02 »
for second hand dellortos?
Offline danny_p
« Reply #4 on: 11 August 2009, 00:12 »
carb manifold and linkages worth more than £100 normaly.  dellortos often go for a bit more than webbers as they do work better
all the VW's have gone bar 1.
Offline deanpompey
« Reply #5 on: 11 August 2009, 08:23 »
id say as a job lot, £350 - 400.
thats considering that the engine is fully rebuilt, as said a home made exhaust manifold is worth nothing really as it could possibly be a hinderance to power...
if i wasn't going vr6 id have been happy to pay 350 all day long
Offline knocker
« Reply #6 on: 23 August 2009, 11:56 »
Have you still got this lot is it for sale
Offline danny_p
« Reply #7 on: 23 August 2009, 13:55 »
90% of manufavtured exhausts arent better than a welll made homemade item, there just made to fit in the hole
Offline deanpompey
« Reply #8 on: 23 August 2009, 20:14 »
but who says its well made??  :laugh:
Offline danny_p
« Reply #9 on: 25 August 2009, 23:01 »
the chinchillas.   dunno if there lieing tho i only understand pixies
