Golf mk4
Wazzzer
Recommended brake pads
Topic: Recommended brake pads (Read 3030 times)
northeast_gti-t
Serious forum addict
"1.8T AGU"
26 July 2009, 21:39 »
looking to paint my brake calipers over the next two weeks and for the front i have decided to remove the calipers for painting as i have a little squeal from the fronts when its dry and its annoying i was going to just remove them and apply anti seize compound to the backs but i'm thinking now well maybe replace the oem pads as its in bits anyway although i have half pad life left
anyway what do you all use on your 1.8Ts or dervs? and could you recommend me any for me to consider
any info would be great thanks
2000 Mkiv GTi 1.8T AGU
warnesey333
Re: Recommended brake pads
26 July 2009, 21:50 »
Im looking to replace my rear pads and will probably be going for mintex I think
B-Reg MK2 - Rebuild in process!
Sheffields Business Directory
Jack Warnes' Portfolio
TONA Valeting
i-Spotted | Spotted something funny or interesting? Post it here!
Steve_PD
Cruising around in a Land Cruiser
26 July 2009, 21:53 »
Ivor recommends EBC yellow stuff
northeast_gti-t
"1.8T AGU"
26 July 2009, 21:56 »
Quote from: Steve_PD on 26 July 2009, 21:53
i'l have a look at them steve i had ebc stuff in my mind earlier
iirc on their website it says the redstuff ones are for cars over 200bhp
johnaldinho89
26 July 2009, 21:59 »
yeh red stuff pads are good plus low brake dust comes of them thats one of the major benefits liek ,but putting red stuff pads on with oem or standard discs wears the surface of ur disc down alot more keep that in mind
and if ur removing the calipers completly ul need to blead the master cylinder after bleeding the calipers to get al the air out , its just two 8mm's on the right side of it
Last Edit: 26 July 2009, 22:01 by johnaldinho89
scottyboy08
Here all the time
mk4 anni rep....1.4 really :P
26 July 2009, 22:57 »
Ebc deffo there great pads
richw911
10k hero
The Linkmeister and an OEM Freak.
Reply #6 on:
27 July 2009, 11:05 »
Ferodo DS2500
Ivor Mk4 Turbo
Forum addict
2014 PP GTi Manual
Reply #7 on:
27 July 2009, 13:45 »
Quote from: richw911 on 27 July 2009, 11:05
Ferodo DS2500
Awesome, but sit down for the price!
Yes, Red or Yellow Stuff pads do the job nicely, are about half the price of the above & are low dust emitting badboys.
Cheapest place for EBC 6 months ago when I was looking, was
www.buypartsby.co.uk
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'!
227
bhp, KO3-S'd AGU,
R-TECH Spec 2 map
, Forge 007P,
Blueflame Turbo-back
, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines,
TT Short-shifter
, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>>
http://www.golfgtiforum.co.uk/index.php?topic=140614.0
DarkGti
Reply #8 on:
27 July 2009, 13:56 »
ive just ordered red stuff pads all round (£120 from ebay) for my 312mm upgrade:grin: sorry to hijack but is there anything else that i should be looking to upgrade? brake lines, discs, fluid???
Last Edit: 27 July 2009, 13:58 by DarkGti
Ivor Mk4 Turbo
Forum addict
2014 PP GTi Manual
Reply #9 on:
27 July 2009, 14:07 »
Pointless upgrading your discs, IMO.
Lines, I would only change if you do track days - Same goes for the fluid, really (although you need to change your fluid every 2 years, regardless of mileage).
227
bhp, KO3-S'd AGU,
R-TECH Spec 2 map
, Forge 007P,
TT Short-shifter
Golf mk4
Wazzzer
