Author Topic: Power steering - slippery when wet  (Read 2175 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 31 August 2004, 13:03 »
My power steering was lost at time when we had a night of rain the other day! it worked for have a turn but try and put it on full lock and it was not there, it was fightening against me, does this indicate the belt is slipping? is it easy to tighten up or replace
Thanks
Offline Gambit
Re: Power steering - slippery when wet
« Reply #1 on: 31 August 2004, 15:01 »
worn belt
just get a new belt fitted, cheap and easy to do
Offline Deefadog
« Reply #2 on: 01 September 2004, 12:55 »
Thanks mate, getting the belt on Friday, also replacing the alternator belt when i am at it!
Is it as simple as just taking the old one off and putting the new one on, any bolts or tensioners I need to be aware of? also is there a certain tension it should be set too?
Thanks
Veedubgt18v
« Reply #3 on: 01 September 2004, 19:41 »
also check the boots on the steering rack, if these are split/absent  the steering can load up because of hydraulic pressure in the toothed bits(water getting trapped in the rack) and make it hard to turn. especially noticeable when going thru puddles!
Offline Deefadog
« Reply #4 on: 01 September 2004, 22:13 »
Thanks will check them too!
Offline Deefadog
« Reply #5 on: 03 September 2004, 18:02 »
Got the two belts (power steering and alternator) today from GSF, the guyz said that they were very similar and either belt would fit each other!
Here is what i got:
Bosh AVX 10 x 950 La
Bosh AVX 10 x 940 La
Anyone know which should go on what?
Thanks
Offline Deefadog
« Reply #6 on: 06 September 2004, 08:26 »
bump
Offline Len
« Reply #7 on: 06 September 2004, 09:47 »
Whichever is the larger one will fit on the alternator.
Mind you i got my steering pump belt from Europarts and it was the wrong one. They even checked it against the engine code and still got it wrong. Got the correct one from a local motor factors and it was cheaper.
www.sas.org.uk
www.the-ace.org.uk
Offline Deefadog
« Reply #8 on: 06 September 2004, 11:28 »
Thanks
There is not much difference between the two, GSF's system said that either could be used??
Should there be a big difference between the both belts?
