Author Topic: Setting up timing on 1.8 8v  (Read 3492 times)
Offline Daston
« on: 26 July 2009, 10:41 »
Hi guys,
My engine is now back together however my timing seems out, turned the engine over by hand and I can feel the pistons hitting the valves. I have found the TDC mark on the cam pulley and can line that up fine, however how do I know when the Crank pulley and oil pump are at TDC?
Offline Jay
  • balding fat cvnt
Re: Setting up timing on 1.8 8v
« Reply #1 on: 26 July 2009, 12:23 »
Check in the maintenance section Up ^ there :afro: full guide by RubJonny :wink:
Offline fused
« Reply #2 on: 26 July 2009, 13:55 »
the 8v don't contact the piston unless you have a high lift cam.
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
follow that to the letter! and you should be ok.  :smug:
Offline Daston
« Reply #3 on: 26 July 2009, 15:56 »
Cheers guys!
So is the 8v a non interface engine then?
Offline fishnchipsx2
« Reply #4 on: 26 July 2009, 19:17 »
Yes, the standard 8vs are non-interference, although that doesn't mean you won't do damage by snapping a cambelt at 6000rpm!
What you believe to be pistons hitting the valves, is probably just the resistance felt when cranking the engine over by hand due to compression.  :smiley:
Offline Ben Lessani
« Reply #5 on: 26 July 2009, 21:38 »
Taking the plugs out when turning should confirm that ^^
Offline Daston
« Reply #6 on: 26 July 2009, 22:37 »
Ahh that makes sense!
Well when the weather decides to stop pi55in it down I shall go and have a look.
Offline Daston
« Reply #7 on: 27 July 2009, 21:52 »
Cheers guys worked a treat! Painted dots onto the crank and oil pump pulleys so its eaiser to line up next time. Am I right in thinking the cylinder to the right is number 1? It's just that I lined the cam saft up and the cylinder to the far right has both valves closed. I always assumed the one on the far left was number 1.
Offline Ben Lessani
« Reply #8 on: 27 July 2009, 21:55 »
Cyl 1 is the closest to the crank pulley.
Offline Daston
« Reply #9 on: 28 July 2009, 12:57 »
Hmm Ok thats what I thought. If the Cam pulley is in the TDC position shouldnt the valves on cylinder 1 be closed? I have lined the marker up with the top of the cylinder head yet 1 valve remains open on cylinder 1.
