Author Topic: Rear exhaust mount  (Read 1074 times)
VW BUSH
Rear exhaust mount
« on: 24 July 2009, 19:17 »
Rear tailpipe mount is flappin up and down.
I cant seem to get to the back of it to tighten it up.
It is not in one of the holes which you can get to the back of any clues
before i go mad......... :angry:
Cant see properly and the floor is wet will i need to jack it in the garage tmrw?
Offline shepgti
Re: Rear exhaust mount
« Reply #1 on: 24 July 2009, 19:23 »
jack and you will see whats goining on, sure it will be an easy fix tbh
VW BUSH
« Reply #2 on: 24 July 2009, 19:32 »
Now very wet on the back after kerbing and climbing under, can see thread going up into chassis but cant get to other side from underneath unless im totaly missing something.
Pulled boot lining out and rumaged around time for Mr torch :smiley:
Offline shepgti
« Reply #3 on: 24 July 2009, 19:34 »
so your saying the actual steel bracket is loose?
VW BUSH
« Reply #4 on: 24 July 2009, 20:10 »
Looks like the bracket has been changed by Powerflow for rubber mount with a threaded insert.
Just looked at Etka and i dont have a bracket as per the diagram.
Looks like i have to take the back box off and hold the nut (if it is still there) and screw the mount back in.
What a pain in the ar@e :angry:
I have got one of the Vag brackets in the golf box so i will have a look at what i can do tmrw, gonna take some pics now :wink:
VW BUSH
« Reply #5 on: 24 July 2009, 20:30 »
My problem, non std mounting :smiley:
« Last Edit: 24 July 2009, 20:46 by VW BUSH »
