Author Topic: Steering Woes  (Read 1457 times)
Offline bong69
Steering Woes
« on: 23 July 2009, 18:53 »
Hi all, out of all the problems with my car this one is the scariest! Its a 90 spec 16v with power steering, when I turn, it seems like the wheels play 'catch up' with the steering input, like theres a slight delay, also if I turn right the steering wheel centres fine but if I steer left the wheel doesnt return quite to centre but the wheels do, its reminding me of dead zones on computer games from my younger days! Any help or pointer much appreciated  :smiley:
VeeDubGTI16v
Re: Steering Woes
« Reply #1 on: 23 July 2009, 19:07 »
try changing the rod ends
Offline bong69
Re: Steering Woes
« Reply #2 on: 23 July 2009, 19:35 »
Thanks mate! I like it.....sounds cheaper than a rack!!!
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
Re: Steering Woes
« Reply #3 on: 24 July 2009, 11:02 »
hi ure best bet is to jack the car up and check suspention for play with the good old shake test and replace accordingly u will prob find bottom arm bushes gone or sumthing along them lines :grin:
Offline MarcN
Re: Steering Woes
« Reply #4 on: 24 July 2009, 12:37 »
Sounds like the track rod ends need replacing, had a similar issue ages ago.
Re: Steering Woes
« Reply #5 on: 24 July 2009, 12:56 »
Could also be play in the rack.
VeeDubGTI16v
Re: Steering Woes
« Reply #6 on: 24 July 2009, 13:00 »
possibly, but what are you gonna try first, the rod ends or the rack?
Offline bong69
Re: Steering Woes
« Reply #7 on: 25 July 2009, 18:09 »
rod ends....cheaper! Actually I had a look at the rods and the rubber does look perished, gonna get some and try em on, thanks for the help chaps!
VeeDubGTI16v
Re: Steering Woes
« Reply #8 on: 25 July 2009, 18:22 »
lol exactly. no wonder tsr charge so much if thats the chain of thought  :laugh:
Offline bong69
Re: Steering Woes
« Reply #9 on: 02 August 2009, 16:49 »
Changed the rod ends....no different, got the front end on axle stands, had a wiggle seemed ok, ventured under the oil covered abyss and bingo! The drivers side clamp over the rack was hanging off! the nuts were hanging on by a thread, tightened up drives lovely! Cheers chaps
