nah bin the resistor and leav eit off, its not required by law or mot. as for the loom, is the headlight loom definitly damaged, or is it just the loom from the fusebox to the switch?
The switch loom I think will have to be a 90spec MK2 Golf/Jetta one, afai there are no other 90spec cars with the same headlight switch on, possibly the Corrado with the MK2 sized switch would work? Not sure if the smaller switch is early/late spec on the rado tho.
As for the headlight loom, again you'll want a 90spec MK2 Golf/Jetta one, thankfully though the headlight loom is seperate from the engine loom. Also for both the headlight and switch loom any spec MK2 should do you, they're all the same.
