Author Topic: brake discs and pads  (Read 1791 times)
Offline Splash
« on: 29 August 2004, 18:13 »
What are the best upgrade front discs and pads for a '94 M-reg Mk3 16v GTi? I need better stopping power as the standard VW items are cr@p compared to the wife's Focus 1.6 brakes. ???
mrwotto
Re: brake discs and pads
« Reply #1 on: 29 August 2004, 21:20 »
Go for some zimmerman drilled and grooved discs and some pagid fast road pads, shud make you stop better ;)
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 29 August 2004, 23:18 »
I've got G60 280mm ones on my mk2 and combined with mintex pads they're awesome. I had the discs drilled by a mate purely for the look, but they don't half scrub off the speed.
if you want serious stopping power you can go for a brembo 4 pot setup with 305mm discs, but you'll have to run at least 16" wheels then. costs are ?400+
Mk4 Golf 150PD
Offline Splash
« Reply #3 on: 26 September 2004, 19:53 »
I've had zimmerman drilled discs and some pagid fast road pads fitted and the brakes are now spot on! many thanks. ;D
Offline sono
« Reply #4 on: 26 September 2004, 23:39 »
I just had my disks 'n' pads done - Brembo disks and mintex pads  ;D chipper stuff for sure.
Offline peterw47
« Reply #5 on: 25 December 2006, 01:01 »
Hi guys,
can I ask where you bought these? I cant seem to find anything for zimmerman on google!!! (theres a first for everything)
Hopefully theres somewhere out there that do deals when buying discs and pads together?
Pete
Offline robster23
  • Now a VW Fox Owner.
« Reply #6 on: 25 December 2006, 21:17 »
Bit of a Hijack but....
I have a 94 Gti 8v too - does anyone know the sizes of front and rear discs and whether they have the cable sensor on the pad or not? It's all a bit confusing when trying to choose parts!
Rob  :shocked:
It's urban right? That means it must be tougher, obviously.... ;-)
Offline vwagain
« Reply #7 on: 26 December 2006, 19:05 »
Rob  :shocked:
Best bet is to take a front wheel off and measure the size of the disks with a tape measure, also look on the front pads to see if you have a wire going to the pads!!.  Im pretty sure the rear disks are the same size on all Mk2's
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline Lewy
« Reply #8 on: 26 December 2006, 21:06 »
Rob  :shocked:
Who ever your buying the spares from just give them your reg, and if they're reputable enough they'll tell you what you need!
