Author Topic: fill back badge  (Read 1429 times)
Offline fieldspor
fill back badge
« on: 19 July 2009, 21:28 »
what the best way to fill the back badge of my mk3 golf so it badge less before i get it sprayed
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: fill back badge
« Reply #1 on: 19 July 2009, 21:32 »
weld a small plate over it.
Offline fieldspor
Re: fill back badge
« Reply #2 on: 19 July 2009, 21:53 »
what about filler
Offline nealey
Re: fill back badge
« Reply #3 on: 19 July 2009, 21:59 »
I wouldnt fill it entirely with filler as it will crack over time
Best bet as mentioned is weld a small plate into it then a small skim of filler over the top
Offline Thom89
  • Looking for an "Icebreaker"
Re: fill back badge
« Reply #4 on: 19 July 2009, 22:35 »
Cut a square plate slightly larger than the circle than your trying to fill, place the new plate over the circle, firmly hold it in place while you scribe round the edge, cut out up to that line, flush fit your new plate in place, tack into position, then seam weld, grind off the weld, and finish with filler
Thom
Re: fill back badge
« Reply #5 on: 19 July 2009, 23:18 »
If you use filler then what can happen is that it will fall out, much better to weld a plate over the top.
I prefer them with the badge to be honest.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: fill back badge
« Reply #6 on: 19 July 2009, 23:20 »
Mine was welded over the top, then filled. So was my aerial hole in the front wing. :cool:
