Author Topic: handbrake issues  (Read 1910 times)
Offline LazyLunatic
  • MK3 20VT Project
handbrake issues
« on: 19 July 2009, 16:00 »
ok so i finally got the rear beam on, went to put my new gti handbrake cables on and they seem too long.
now would the gti have a different handbrake mech?
i did take the metal sleeves off the car, that take the cable into the cabin..... got a feeling that they are needed. cant really explain it, but they make it so less cable is in the cabin and it is more slack under the car if ya get what i mean.....
only problem being is i had to take the sleeves out cause the old handbrake cables are stuck in them. so i think i need new ones, which means a trip to the stealers...... joy.
any shine light on this situation?
cheers.
Offline LazyLunatic
  • MK3 20VT Project
Re: handbrake issues
« Reply #1 on: 20 July 2009, 13:44 »
anyone changed there cables before and can shed some light here?
going to vw today to get some new sleeves, hopefully that will sort it :)
« Reply #2 on: 20 July 2009, 13:50 »
I take it you had drum brakes before then? if so yes you need MK3 GTI handbrake cables
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 20 July 2009, 14:34 »
got them but they are too long.... thinking i need to use the metal sleeves to take the cables into the car. i guess that stops excess cable moving into the cabin, so the cable is just slack. hope that makes sense :undecided:
cheers :)
« Reply #4 on: 20 July 2009, 14:56 »
yeah you do, if you pulled the slieves out with the old cables you need to put them back in!  easily done both of mine did the same when i swapped the cables over on my MK2 GTI. bit of a pain to get them back in as you have to lift the carpet to see the tubes. even worse in a mk3 as ya gotta remove the console surround, which I found to be a mare unless i was doing it wrong  :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 20 July 2009, 15:18 »
yeah shouldnt to bad getting them in. centre console came out real easy on mine just a couple screws, mayb you were trying too hard :D :D :D
only problem i got is i took the sleeves out cause they are stuck on the old cables. not a chance of reusing them lol. just going to grab some new ones at vw.
thanks once again! got to say, following your advice for converting to gti brakes all round and keeping 4 stud has worked a treat! :afro:
« Reply #6 on: 20 July 2009, 15:49 »
yeah mine were pretty jammed, but i was buggered if i was going to let them beat me so I got medievil with the cables and got em loose!  dunno what I was doing wrong with the console, i found it was an utter sod to get it past the handbrake.  or maybe it was the centre console I struggled with?  dunno I must've blacked out most of the memories from that day, MK3 heater matrix swap is something I dont want to have to do again  :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #7 on: 20 July 2009, 16:25 »
lol.
btw you cant be telling anyone that you struggled with things, you are meant to know all and be awesome. your ruining your reputation!! :D :D :D
haha only joking. thanks again m8 :afro:
Offline VR6-Joe
« Reply #8 on: 20 July 2009, 17:13 »
To be honest I have trouble getting the centre console out too lol. I find it easier with the seats removed though because there's more room to get it past the handbrake.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline LazyLunatic
  • MK3 20VT Project
« Reply #9 on: 21 July 2009, 00:04 »
ahh sorry you mean the centre console, never tried taking that out... only need to take the handbrake surround off to access the handbrake.
LL ;)
