Author Topic: Hub Housing  (Read 1229 times)
Offline KelvinIOW
Hub Housing
« on: 28 August 2004, 14:01 »
Is the hub housing on the GTI MK2 the same as any other MK2 golf can i replace my hub with anyone
Cos i can get hold of one from a standard golf any help would be great as its my last hope to be able to fix my car!
If that doesnt work then i may be having to strip the car of all good parts and sell them seperatly i dont wanna do that but i might have to :(
Offline richandhazel
Re: Hub Housing
« Reply #1 on: 30 August 2004, 13:06 »
I've had a look in the ETKA and assuming your vehicle is 1991, the part number of the housing is: 191 407 256D
This assumes you don't have ABS as the housing is a different part number if ABS is fitted: 191 407 256C
All the following engine codes use the same housing: NZ, HZ, 2G, PN, RF, EZ, JP, ME, 1V, JR, MF, RA, SB, RH, GU, RP, RV, PB, PF, ABN
There is another housing for the same year: 357 407 256C
This is fitted to engine codes: KR, PL, PG
Hope that helps
Engine codes/Engine sizes:-
NZ, 2G = 1300
HZ = 1050
PN, RF, EZ, JP, ME, 1V, JR, MF, RA, SB, ABN = 1600
RH, GU, RP, RV, PB, PF = 1800
« Last Edit: 30 August 2004, 13:18 by richandhazel »
Offline KelvinIOW
Re: Hub Housing
« Reply #2 on: 30 August 2004, 16:16 »
THANX alot for that rich it looks like i can get the hub off the carin the scrappy then thanx very much 4the help ill let u know if i get the car sorted!
thanx again :)
