Author Topic: Big Turbo time!!  (Read 12793 times)
Offline RedRobin
Re: Big Turbo time!!
« Reply #60 on: 25 September 2009, 00:05 »
Yep, I've been running nearly 400 Nm on DSG for some time and without any problems. I've had 2 DSG oil + filter changes so far.
Offline Hurdy
« Reply #61 on: 25 September 2009, 21:17 »
I thought that the rating of the DSG box was officially 350nm :wink:
The stock R32 has 236lbft and the same DSG as the ED30/GTI/TDI = 320nm as standard.
From VW's site...
"Both DSG gearboxes are application-specific. The 6-speed is paired with high torque engines (up to 350 Nm) while the 7-speed variant is more effective in combination with smaller engines and torque outputs of up to 250 Nm."
Mine is currently 489nm :shocked: with the DSG box remapped to accept torque up to 500nm :cool:
Seat Leon Cupra Black 290 DSG
Offline Dave-turbo
« Reply #62 on: 28 September 2009, 12:40 »
thanks for the info guys.
still not sure if i wanna get a ED30 and max out the k04 or save some £ and buy a normal GTI and use the saved money towards a GT30 with rods and pistons aswell as RS4 injectors.
is there anybody in the uk offering remaps for this kind of setup?
Offline Hurdy
« Reply #63 on: 28 September 2009, 23:33 »
Revo do GT30 maps. :smiley:
Offline Teutonic_Tamer
« Reply #64 on: 12 October 2009, 10:49 »
Would RS4 injectors offer any benefit? :undecided:  And more importantly, would they actually work, because the RS4 needs two ECUs to work!
I feel like a homo
Offline monzablue16v
« Reply #65 on: 12 October 2009, 14:14 »
Bigger injectors, flow more fuel.
Offline Micky 32
« Reply #66 on: 12 October 2009, 19:13 »
TT the RS4 ones do work, actually as far as i know the Revo stge 3 ko4 upgrade in the US uses the RS4 ones. Maybe the 2 ECU's are because twice the cylinders?
2008 Octavia vRS race blue, xenons, parking sensors. Mods: Evom's, TBE milltek, Autotech fuel pump, Forge twintercooler, KO4, 325bhp on JKM RR
Offline Hurdy
« Reply #67 on: 12 October 2009, 19:52 »
Try phoning VF up and ask about their modified injectors.
They have the right spray pattern as opposed to the RS4 spray pattern which is altogether different and not as efficient.
Chris at Regal swapped to the VF ones and his car instantly made more power. :smiley:
Offline Dave-turbo
« Reply #68 on: 13 October 2009, 00:37 »
do they supply these on there own? i plan on using a gt3076r and following some of the us boys and try get in to the high 4s low 5s
« Reply #69 on: 13 October 2009, 13:51 »
OK, so I know where to go looking if my RS wont fire up!  :evil: :evil: :evil: :evil:
It is actually to do with the rev limit.  The B6/B7 S4 which had fundamentally the same V8 made do with just one ECU.  The standard RS4 revs upto 8,250 - and a single ECU cant cope with the number of calculations.  And my Revo stage 1 on the RS4 has raised the rev limit even higher - to just under 9,000 rpm (along with deleting the 'soft' speed limiter too) - and it is fcukin mental now!  :evil: :evil:
I feel like a homo
