Author Topic: Removing top end  (Read 1507 times)
Offline Daston
Removing top end
« on: 18 July 2009, 16:36 »
Hi guys,
Another question lol
Just removed the topend after draining all the coolant however some still went into the cylinders. How bad is this? Am I going to have to take the sump off and get all the oil out or is it ok to fire up and see what happens????
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
Re: Removing top end
« Reply #1 on: 18 July 2009, 16:47 »
hi you will always get some in the engine. all u gotta do is wipe the excess out of the bores then put it back together and change the oil and filter which we always do when we take a head off at work  hope that helps:grin: :grin:
Offline Daston
« Reply #2 on: 18 July 2009, 18:50 »
Sweeeet :) Good call on the oil filter, will change the oil as well incase of mayo.
Offline deanpompey
« Reply #3 on: 18 July 2009, 21:06 »
when i fitted gti head to my driver we fired her up on the old oil and coolant so as to check for leaks etc, then flushed everything out and filled up with fresh. oil change after 1k miles is also good idea :)
Offline th3_f15t
« Reply #4 on: 19 July 2009, 10:51 »
When you flushed it, did you use proper flush chemicals? I've been recomended not to if I did it to my Golf GTi.
Moving over to Flickr, sorry for the broken picture links!
« Reply #5 on: 19 July 2009, 23:25 »
Why not, engine flush should not hurt it.
Offline deanpompey
« Reply #6 on: 20 July 2009, 14:41 »
yes was flushed with wynns engine flush, coolant system was flushed with water.
there are horror stories about flushing older engines out as there is a possibility that its the sludge and crap in the engine that fills hairline cracks etc and if you flush it away your left with a screwed engine. however, if the car has been looked after and properly serviced at regular intervals, then there should be no problem.
mine had 188k on clock, and didnt cause a single problem :)
« Reply #7 on: 20 July 2009, 14:58 »
yeah i did a flush in my 160k GTI. it cleaned out my oil cooler really well, so well it took all the crap out that was holding it together. oil in water yay. bypassed it and eventually put a 2.0 engine in there  :grin:
engien itself was fine, pulled well and didnt smoke before or after the flush.
Offline Ben Lessani
« Reply #8 on: 23 July 2009, 09:08 »
yeah i did a flush in my 160k GTI. it cleaned out my oil cooler really well, so well it took all the crap out that was holding it together. oil in water yay. bypassed it and eventually put a 2.0 engine in thereĀ  :grin:
+1 - although I used some ATF, the theory is the same. My car burns oil like theres no tommorow and I don't think I have the time to cover 180k to fill the gaps with oil crud.
