Author Topic: mk2 rear window installation???  (Read 1273 times)
Offline k33p it low
« on: 18 July 2009, 16:35 »
Hi,
I got hold of a mint bootlid in the same colour as my car and I now want to swap it for the rusty one thats on my car.
I know how to remove the rear window from the bootlid as I ve done it before, but how do I get the glass back into the bootlid???
would be great if someone could tell me how to do it so I can swap the boot tonight or tomorrow.
Offline Thom89
  • Looking for an "Icebreaker"
Re: mk2 rear window installation???
« Reply #1 on: 19 July 2009, 00:48 »
With the rubber fitted to the glass, run a legnth of string (4-5mm curtain cord is ideal) around the edge of the rubber making sure that its snuggly seated in the groove, and leaving a tail that you can grab hold of.. place the glass squarly in the appature, you may need help for the next bit, lift the tailgate, or easier still, get in the boot, then, with someone gently pushing the screen directly into the tailgate, pull on the string, you will start to see the lip of the rubber, crossing the lip of the tailgate, as you pull the string, keep your hands close to the glass to avoid ripping the rubber, once all the string has been pulled sucessfully, you will then need to "bed" the screen, by gently, but firmly slapping on the glass, all around the outside edge, you'll see the glass move into the correct position (just a few mm's) You may want to spray some WD40 onto a rag, to run round the edge of the rubber, just to help the rubber seat a little easier before fitting :lipsrsealed:
Thom
« Last Edit: 19 July 2009, 02:02 by thom89 »
Offline k33p it low
« Reply #2 on: 19 July 2009, 11:54 »
Thom
Sweet!
I ll try it next week and let you know how I get on.
cheers!
