Author Topic: Powerchip - before and after  (Read 26580 times)
Offline tony_ack
« on: 17 July 2009, 23:01 »
Sorry if this is a bit long, just thought I'd share my findings with anyone planning to get a chip for a Digifant!
I posted some time ago about whether or not to remove a chip I had in the ECU of my digi. In the end, I decided to change the ECU for a non-chipped one, as I suspected it was covering for a bad tuning set up. Several other jobs were done on the car at the same time as the ECU swap, and when I got it back, it felt much better (but any one of a number of changes could have caused this).
Since then, I've got the timing sorted on the car, and the CO there or thereabouts, and it drives like it should now. However I was intrigued yesterday when reading up on what powerchip actually does, and decided to try the chip again now that the car was running correctly, to see if it made any difference.
As many of us know, the Digifant is a pretty crude management system, and only a limited number of things can be changed by a new chip - specifically the rev limiter and the fuel maps.
I was interested to read that Digis tend to lean near the top end, and that one benefit of the chip was to adjust the map to account for this. People have also mentioned that the power delivery is smoother, and torque is better lower in the range, which I guess is also caused by the adjusted fuel map.
I'm not so interested in the increase in the rev limiter, as most of the power has gone before you reach that!
So, what I set out to test was:
1. Is there an increase in power lower in the rev range
2. Does the car accelerate more smoothly
3. Does the car pull any better at the top end
4. Is fuel economy affected
5. To sum it all up, does the car seem faster and is it nicer to drive?
The car - standard 8v Digi, other than a Jetex Panel filter. AFM is standard and unmodified, and tests within tolerances. Timing is correct.
The chip - The chip is in my old ECU, which is a DB code. The original chip on the bottom board has been replaced by the Powerchip. Swapping the ECU was a 5 minute job - would probably have been less if I didn't have to go into the house to get my 10mm socket!
Not very scientific, but I compared the car before and after by driving it hard (but safely of course) down some local country lanes. So, what did I find with the chip installed?
1. The car does seem to pull better from lower in the range. There was perhaps the tiniest hint of digilag before, but that's now gone.
2. The first thing I noticed was that the car just seemed smoother, and even more refined than normal. I didn't think there were any flatspots before, but I must have been wrong, as it feels a lot better now! I did however almost stall at a roundabout, as I didn't give it enough revs  :embarassed: I'm putting this down to a change in the setup and I wasn't used to it  :smiley:
3. The car pulls a little better between 5.5k and 6k, but it didn't exactly blow me away, and isn't really worth waiting for (still change up at 5.5k!). However it did seem noticably more eager between 4.5k and 5k. I didn't get to the limiter, so I don't know what it was set at.
4. Economy for my little drive (37 miles) was 37.7mpg, which when adjusted for the speedo overread is about 34mpg.  This compares with about 38mpg (adjusted to about 34.5mpg) for similar driving previously.
5. To sum up the power delivery is definitely smoother now, and having more power lower down makes it easier to drive 'normally'. Performance-wise, the chip probably just about shades it, but there is in reality only a subtle difference. That said, it now feels like a different car to drive - not necessarily in a bad way, but not in a good way either. Just different.
I think because my chip is free, it's probably worth leaving it in, however I would have been disappointed had I paid a lot of money for it. It has enough benefits to make it worthwhile, but not essential.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline Khare
  • The bear that khares
Re: Powerchip - before and after
« Reply #1 on: 17 July 2009, 23:09 »
nice write up dude! :afro:
Offline tony_ack
« Reply #2 on: 18 July 2009, 21:06 »
A quick update...
Took it for another drive today, and got some slight popping from the exhaust on the downshift - suspect that the new map is causing it to overfuel slightly.
1995 VW Corrado VR6
Offline ReDBull
« Reply #3 on: 20 July 2009, 13:53 »
Have you thought about getting it on a RR with both ECU's to see what differance (if any) it does make?
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 21 July 2009, 16:38 »
Thats a good idea but in theory you'd be hard pushed to get a fair test unless you really tried hard. Things like Room temp, engine temp etc etc all make the car perform differently. Plus the fact rolling roads aint exactly a cheap venture!
Offline russ-vdub
« Reply #5 on: 21 July 2009, 16:39 »
But thanks for the write up chap!
I got one of these chips of ebay a while back and never had any problems, just smoothed out the accelleration a bit. Beauty is its just an EPROM chip so can now reproduce these at work whenever i want :)
Offline ReDBull
« Reply #6 on: 21 July 2009, 17:37 »
And how much would you charge for said reproduction???
Offline cняis
« Reply #7 on: 21 July 2009, 19:04 »
with one fitted to my old 8v it pinked like a b!tch...
it did go better though.
Offline 6foot6
« Reply #8 on: 22 July 2009, 10:41 »
it prob just whacks on more advance lower down and leans out the mixture a little.
Hence why it feels different..
I would get it on a rolling road and check the AFR across the rev range and make sure its not leaning out and what the power/torque curves look like.
With the MR2 with stock ECU it has a afr of around 10:1 at WOT, with the after market one Ive leaned it out to around 11.5:1 and gained 25HP and 20 lbs/ft of torque.
Golf GTi 8v Alpine white - Project track shlag - TLC needed - KnN/Scorpien full system oval tail pipe, rust here and there.
1991 Toyota MR2 MK Revision 1 Turbo, rev 3 LSD, CT20b Turbo, HKS Exhaust, Blitz Downpipe 244HP@the wheels @ 13psi - 12.9 SQM :D
1994 BMW 730 V8 fully loaded 220BHP
Offline danny_p
« Reply #9 on: 22 July 2009, 11:18 »
has wideband controller :).  need sensor :(    .  but can just datalog a run down the road will give same info.
all the VW's have gone bar 1.
