Author Topic: Vento won't start, IN 02 appears on dash  (Read 3589 times)
Offline Jimp
« on: 17 July 2009, 18:52 »
Went out to start up the Vento a few minutes ago and the engine wouldn't start  :lipsrsealed: IN 02 flashed up on the dash, here's a picture:
Nothing has changed in the car since I took it for a drive yesterday. No problems on the drive. It's just been sat on the driveway since last night  :sad:
Any ideas what's wrong?  :sad:
Not low enough mk5
Not on the road enough mk3
Offline Mikester
  • Civic Type R
Re: Vento won't start, IN 02 appears on dash
« Reply #1 on: 17 July 2009, 18:53 »
In o2 just means its due a service and is a reminder.
has nothing to do with it not starting.
What is it doing before it wont start? Does it turn over? Igintion lights come on? Fuel pump prime?
Offline shepgti
« Reply #2 on: 17 July 2009, 18:53 »
in 02 is just a service reminder, elaborate on 'it wont start'... is the engine turning over? http://www.golfgtiforum.co.uk/index.php?topic=91975.0
EDIT:jsut too fast for me mikester :grin:
Offline Jimp
« Reply #3 on: 17 July 2009, 19:02 »
The engine won't turn over. I can't explain it much better than this: when I turn the key it goes wooo wooo...woo...wooo.....wo.... and nothing.
Engine is a 1.4 AEX too if that helps.
Not low enough mk5
Offline Mikester
  • Civic Type R
« Reply #4 on: 17 July 2009, 19:05 »
What year is it? Not sure if it would be an imobiliser issue on a 1.4, as im not sure if they have them. Dont think they do.
I presume the woo woo is the fuel pump priming.
Ignition switch? although dont normally break over night, its normally a grudual trouble starting with the key, over time.
Starter motor? Tried giving it a wack?
Offline Jimp
« Reply #5 on: 17 July 2009, 19:18 »
It's a 96.
Haven't tried giving it a wack, reckon I should?   :laugh:
Not low enough mk5
Offline Mikester
  • Civic Type R
« Reply #6 on: 17 July 2009, 19:24 »
Well the starter motors can get stuck, and giving them a wack frees them up.
Although i doubt its your problem.
Very odd that over night its stopped working. Previous to today, have you had any problems?
Offline Jimp
« Reply #7 on: 17 July 2009, 19:30 »
Nope, no problems. Sailed through the NCT (Irish MOT equivilent) last week.
I'll go outside and give it a wack and see what happens.
Not low enough mk5
Offline Jimp
« Reply #8 on: 17 July 2009, 19:43 »
Ok went out and watched as the key was turned. The belt on the left side of the engine (timing belt? I don't know much about this stuff  :embarassed:) Turns a little then stops, then turns some more and stops but won't keept going. It looks the same as the belt on the bottom left in this picture (not my car)
Not low enough mk5
« Reply #9 on: 17 July 2009, 20:50 »
So is it not turning over then.
