Author Topic: Wiper stalk - MFA - faulty  (Read 1378 times)
Offline billy_vw
« on: 17 July 2009, 13:56 »
Im guessing this is the problem - would be nice if others can confirm
intermitent fault.
Wipers only work of super fast and MFA not working.
Wipers does not work on normal speed
Then it may work for 30 seconds  :undecided:
Im guessing the stalk needs changing.
Mines a 94/M non airbag model, are the stalks different on airbag models?
Thanks
Billy
MK5 GT TDi
Offline Gerko
Re: Wiper stalk - MFA - faulty
« Reply #1 on: 17 July 2009, 19:06 »
Mine did that , Took it apart cleaned the contacts , job sorted , no need for expensive VAG parts a bit of wet and dry sorted mine.
locin78
« Reply #2 on: 18 July 2009, 17:35 »
hi, i have a similar prob with mine did you have to remove the steering wheel??
Offline Vesper
« Reply #3 on: 20 July 2009, 13:13 »
Have exactly the same problem on my mk3 (again) - wipers only work on superfast & slow. Happened about a year ago, cleaned up the contacts & seemed to work fine again. Gonna try this again see how it goes. With mine, I know the problem's back when the wipers fail to return to fully down & off position.
locin78
« Reply #4 on: 27 July 2009, 20:00 »
i removed my wheel and a few other bits and took of my wiper stalk off and cleaned it, it still did not work prop so am going to replace it! going to try and get a 2nd hand one and go from there.
Nic
