Golf mk3
hardmonkeys
high speed vibrting....
Topic: high speed vibrting.... (Read 4003 times)
joff GTI
GTI forum regular
16 July 2009, 18:04 »
my cars started vibrating at 80mph+ the steering wheel for example , i recently fitted some mk4 montreal alloys & had them balanced , so i`m unsure of what it could be... any ideas? is this common? cheers...
ianw3321
Guest
Re: high speed vibrting....
16 July 2009, 18:06 »
Something must be out of balance or loose.
Adam
Forum addict
16 July 2009, 18:13 »
buckled wheel
improper balancing
Down Hill From Here.
joff GTI
GTI forum regular
16 July 2009, 18:17 »
Quote from: GTiAdam on 16 July 2009, 18:13
buckled wheel
improper balancing
is there a way you can tell if a wheels buckled?
christomk3gti
16 July 2009, 18:32 »
mine is the same.
on standard gti 8v wheels, its annoying. I'm hoping the wheels just want balancing.
Black 8v GTI............. Whats a Waffle Valve?
Mikester
Forum addict
Civic Type R
16 July 2009, 18:35 »
tracking?
ianw3321
Guest
Reply #6 on:
16 July 2009, 18:37 »
You say the wheels have been balanced so they cant be buckled or it would have showed up. But do go and check that the wheel nuts are tight.
christomk3gti
Reply #7 on:
16 July 2009, 18:38 »
if the tracking is out, doesnt the tyres wear more on one side?
mine are pretty even, exept when flinging it round bends
ianw3321
Guest
Reply #8 on:
16 July 2009, 18:44 »
Yes it can do but doesnt usually cause a vibration
christomk3gti
Reply #9 on:
16 July 2009, 18:49 »
so its more likely to be wheel balancing then, buckled wheel, dodgy suspension, or loose wheels, and maybe tyre pressure?...
i'll check on these tomorrow if it stops bluddy raining.
thanks guys.
Golf mk3
hardmonkeys
