Author Topic: Fuel Gauge Reading Intermittent  (Read 3243 times)
Offline funkyfive
« on: 16 July 2009, 15:08 »
Yesterday my gauge started going crazy, and the reading is up and down. Any ideas?
Re: Fuel Gauge Reading Intermittent
« Reply #1 on: 16 July 2009, 15:11 »
Sender unit.
Offline funkyfive
« Reply #2 on: 16 July 2009, 15:14 »
Where and what is that?  :embarassed:
« Reply #3 on: 16 July 2009, 15:45 »
Top of the fuel tank, tells the gauge how much is in the tank.
ianw3321
« Reply #4 on: 16 July 2009, 15:52 »
If the temp guage is moving about too it is the voltage regulator. If only the fuel guage then as wayne says. To test a tank unit remove the wire switch on the ignition and touch the wire to earth. If nothing happens look elsewhere but if the guage goes all the way to full and you are not getting an accurate reading when connected then it is a faulty tank unit.
Offline christomk3gti
« Reply #5 on: 16 July 2009, 17:31 »
my fuel gauge does strange things also, when around half tank, might suddenly drop to quater of tank, then after abit, go back up.
my temp gauge seems ok i think, depending on how hot it is, It can stay at the middle, or if its not too hot, it stays around 75-80 degrees.
Is this normal?
Black 8v GTI............. Whats a Waffle Valve?
ianw3321
« Reply #6 on: 16 July 2009, 17:56 »
My gauge moves up and down as I brake / accelerate but thats just the fuel moving around in the tank as long as its accurate at a steady speed on a level road.
« Reply #7 on: 16 July 2009, 18:21 »
ohh right, but what about the temp gauge, is mine normal?
ianw3321
« Reply #8 on: 16 July 2009, 18:23 »
I would say so mine gets halfway stuck in ttaffic but sits at around 85 on the open road.
« Reply #9 on: 16 July 2009, 18:30 »
thanks mate. exaclty what mine does
