Author Topic: Super or regular?  (Read 67781 times)
Offline AlanD
  • MK5 2.0T 16v
Re: Super or regular?
« Reply #130 on: 18 August 2009, 16:01 »
Why would you want to do that? Just fill her up till she clicks is surely the easiest and most sensible option?
Offline Teutonic_Tamer
« Reply #131 on: 18 August 2009, 16:12 »
Well you can get another 60-70mile range - and if you have a Tesco 5p a litre off voucher, you might as well max out your discount.  Anyhooooow, I hate filling em up - rather be driving em!
I feel like a homo
Offline matchboy
« Reply #132 on: 18 August 2009, 16:18 »
the tesco 5p off vouchers are a total con.  next time you get one, look at the next petrol station near you, i guarantee tesco's will be 3-4p more expensive, so you're only saving 1p.  every little helps - total con job.
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline Gazdebaz
  • Lovin it.
« Reply #133 on: 18 August 2009, 16:27 »
Depends where you live, Shell garage 100 yards from Tesco's exactly same price.
Tornado Red 5 door GTI, DSG, Winter Pack, Lux Pack, RCD510+dynaudio, Park Assist with Camera, Sunroof, Cruise, Mud Guards & FT indicator.
Offline matchboy
« Reply #134 on: 18 August 2009, 16:33 »
down saaaaf its happened everytime i get a voucher, is a total con.  but then that's the price i pay for a better standard of life down this way hehe!! :grin:
Audi RS5 2018
Offline Gazdebaz
  • Lovin it.
« Reply #135 on: 18 August 2009, 16:44 »
Beter standard of living  :smug: Not going to bite with that comment..... At least our drinking water hasn't been through about 4 sets of kidneys :grin:
Anyway local petrol price at both Shell and Tesco 100.3p
Offline matchboy
« Reply #136 on: 18 August 2009, 16:47 »
 :grin: sorry, couldn't resist it!
Audi RS5 2018
« Reply #137 on: 18 August 2009, 17:00 »
Round my way, Tesco juice does vary quite a bit in price.  If I go into the city (or its outskirts), Tesco and Shell are generally on par, but any Tescos out in the sticks are usually about 5p a litre more!
BUt anyway, even on the odd occasion when Tescos is more expensive than V-Power, I'll normally always go for the Tesco stuff, because it has been repeatedly proven to be more 'stable' than V-Power.  Oh, and SWMBO likes spending my clubcard vouchers, whereas she turns her nose up at the Shell Drivers Club vouchers!  :rolleyes:  :grin:
I feel like a homo
Offline DonnieDarko
« Reply #138 on: 18 August 2009, 17:50 »
i've used super all but about ten times in my impreza wrx- tbh i've noticed very little difference in it power/ fuel economy, and the filler cap says 98+.
Yes, but what type of 'super'?  Becauase they aint all the same.  Most supers in the UK are actually only 97 RON - so hardly an increase over the standard 95.  But Shell V-Power and Tesco 99 are both 99 RON - which is really quite a difference over 95 RON.
Secondly, because you 'normally' use 95, then your ECU has probably 'adapted' to run with less advance on the timing as its 'default' settings - and when you do occasionally give it a splash of super, the ECU doesn't have long enough to properly adapt, before you end up slinging poverty-spec juice at it again!  :evil:
in fact running a tank of 95 after 98/99 seems to be better if anything- but the scoob doesn't have a range computer- just a rather uneven fuel gauge.
That IS a well known phenomenom in that scenario, across most makes of car.  The in-depth answer is a bit 'tecchy'.
i'll probably give the gti a test and if i see a benefit out of super i'll use it, otherwise i'm planning to go back to regular
If yours is a Mk6, then it would seem you may not actually notice any benefit with super.  :undecided:  With a remap though, that is different!  :wink:  :tongue:
I use shell v-power or tesco 99, only buy super from bp/esso/ total if i have to and 95 only if i'm out in the sticks with no alternative- so think you got the wrong end of the stick- very little poverty fuel for me!
i was assumed the ecu still thought it was on the good stuff when i put in the normal, but don't understand why it seemed to be better on fuel then?
maybe i'll alternate on the gti
Just sold an S5 - previously mkV R32 DSG Metallic Grey with RNS 510 (thanks to MortyGT140)
Offline AlanD
  • MK5 2.0T 16v
« Reply #139 on: 19 August 2009, 09:49 »
Forgot to fill up so had to use the Shell on the way to work this morning. 1.11.9 :shocked:
Stuck in 15 quid and will be using the Tesco later this evening, its always MUCH cheaper.
