Author Topic: Super or regular?  (Read 67894 times)
Offline VWKev
  • Please Support Non-Human Rights
Re: Super or regular?
« Reply #120 on: 16 August 2009, 02:52 »
« Last Edit: 16 August 2009, 03:05 by VWKev »
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline simonpolly
« Reply #121 on: 16 August 2009, 14:26 »
On the Golf Gti mk6 under the petrol cap it says to use a min 95 ron,i suppose they have kind of left it to the driver to choose
Golfgti build quality is average at best.
Offline DonnieDarko
« Reply #122 on: 17 August 2009, 19:33 »
i've used super all but about ten times in my impreza wrx- tbh i've noticed very little difference in it power/ fuel economy, and the filler cap says 98+.
in fact running a tank of 95 after 98/99 seems to be better if anything- but the scoob doesn't have a range computer- just a rather uneven fuel gauge.
i'll probably give the gti a test and if i see a benefit out of super i'll use it, otherwise i'm planning to go back to regular
Just sold an S5 - previously mkV R32 DSG Metallic Grey with RNS 510 (thanks to MortyGT140)
Offline Wurzel
« Reply #123 on: 18 August 2009, 00:25 »
It's really hard to fill up with super when you pull in at the petrol station with an empty tank and you know it's going to cost about £40 to fill it up and you have the option of it costing 7% MORE than that!
1999 mk4 1.8 n/a AGN Silver Grey
***Looking for one 16 inch wheel, Montreal 2*** and a rear parcel shelf (without speaker holes!)
Offline keelaw
  • It's here!
« Reply #124 on: 18 August 2009, 00:41 »
£40 quid to fill it up?!  how big is the golf's tank?  that's a bargain!!
my old 5 series took near 80 quid!
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline AlanD
  • MK5 2.0T 16v
« Reply #125 on: 18 August 2009, 09:48 »
FYI Golfs tank is 55 litres.
Offline Teutonic_Tamer
« Reply #126 on: 18 August 2009, 15:48 »
OK, thanks for clarifying that Simon.
So yeah, the Mk6 GTI in standard tune should make its max quoted power and performance figures with just 95 RON - though as I previously mentioned, don't use Asda, Sainsburys or other cheapo standard unleaded.
And a couple of tankfuls of V-Power, Tesco 99, Total Excillium or BP Ultimate every now and then should help keep the innards clean.
I feel like a homo
« Reply #127 on: 18 August 2009, 15:57 »
Yes, but what type of 'super'?  Becauase they aint all the same.  Most supers in the UK are actually only 97 RON - so hardly an increase over the standard 95.  But Shell V-Power and Tesco 99 are both 99 RON - which is really quite a difference over 95 RON.
Secondly, because you 'normally' use 95, then your ECU has probably 'adapted' to run with less advance on the timing as its 'default' settings - and when you do occasionally give it a splash of super, the ECU doesn't have long enough to properly adapt, before you end up slinging poverty-spec juice at it again!  :evil:
That IS a well known phenomenom in that scenario, across most makes of car.  The in-depth answer is a bit 'tecchy'.
If yours is a Mk6, then it would seem you may not actually notice any benefit with super.  :undecided:  With a remap though, that is different!  :wink:  :tongue:
I feel like a homo
« Reply #128 on: 18 August 2009, 15:59 »
But on the Mk5 which was specifially OEM set up to use 98 RON, it was well proven that 95 increased fuel consumption, as well as knocking off performance.  So six of one, half a dozen of the other!  :wink:
I feel like a homo
« Reply #129 on: 18 August 2009, 16:00 »
Yeah, but you can also squeze in an extra 10 litres after the 1st click stop.  Just search the Mk5 section for some 'cautions' if you do though!
I feel like a homo
