Author Topic: mk3 tdi leaking fuel pump?  (Read 1592 times)
Offline aaron1980
« on: 14 July 2009, 09:18 »
Hi my tdi golf has started leaking from the top of the fuel pump where the accelerator shaft go's into the pump so i took of the cable and leaver to have a look and its leaking out of the o'ring around the top of the shaft where it meets the pump. my question is can you get this o'ring from anywhere? thanks for any help :grin:
Re: mk3 tdi leaking fuel pump?
« Reply #1 on: 14 July 2009, 10:10 »
If it is a Bosch pump then a diesel specialist should be able to help.
Offline Live in Hope
« Reply #2 on: 14 July 2009, 18:51 »
Where are you based?
Offline aaron1980
« Reply #3 on: 14 July 2009, 21:37 »
Hi i live in devon i have now ordered a seal set from the vw dearler but i will have to see how i get on fitting it. they said its a bit fiddley so we will see. my main problem is if the pump packs up the car is not worth fixing! i wish i had left it alone in the first place :cry:
« Reply #4 on: 14 July 2009, 21:44 »
Might be worth trying:
City Auto Diesel Ltd
37 Sutton Rd
Coxside
Plymouth
Devon, PL4 0HE
Tel: 01752 267144
Or.
Electro-Diesel (RCJ) Ltd
4, Goshawk Units
Osprey Rd
Sowton Industrial Estate
Exeter, Devon EX2 7JG
Tel: 01392 208090
Used them both in work lots of times with no issues.
« Last Edit: 14 July 2009, 21:45 by Wayne »
Offline aaron1980
« Reply #5 on: 14 July 2009, 21:55 »
Thanks Wayne i will see how i get on at the weekend and if i cant do it i will give them a try. :grin:
« Reply #6 on: 14 July 2009, 21:57 »
No worries.
