Author Topic: valve stem oil seals!  (Read 2788 times)
GTI-BOY
« on: 26 August 2004, 17:06 »
I've seen the threads about blue smoke, rocker cover breather, valve stem oil seals etc, I got the cylinder head on my 8v digi reconditioned about a 3 months ago, but recently when I step off on the accelerator at high revs, leave it for a few seconds then re-accelerate I get a huge puff of blue smoke!! :o  It doesn't do it on tick over or on normal acceleration and i can avoid it by dipping the clutch when I'm slowing down, it just happens when I back off on the throttle for a few seconds and re-accelerate! The engine was rebuilt, new piston rings, cylinders honed etc etc. I know it's not the breather pipe thats blocked . Would it be anyway possible that the valve stem oil seals could go so quickly??? ??? I don't want to strip it again!!!!!!!!! >:( >:( >:( :o :-X
Offline richandhazel
Re: valve stem oil seals!
« Reply #1 on: 27 August 2004, 12:58 »
Certainly sounds like valve guide oil seals. Shouldn't go that quickly unless the guides themselves are worn. As you have had the head reconditioned, assuming that was done properly, they should all be ok. Maybe one of the seals were damaged when pulled over the valve stem :-\
GTI-BOY
« Reply #2 on: 27 August 2004, 13:45 »
I'm just wondering now if I drove it too hard too soon? I took it very easy for the first 1000 miles to let the new rings bed in nicely and then got back into normal driving (not rallying! ;)).
Has anyone changed the seals with the head in situ? I really don't fancy taking those manifolds and stuff off. I know you can get an airline that you connect to the spark plug hole to pressurise the cylinder etc etc, but I can imagine (knowing my luck!! :D) putting a little pressure on the valve and it falling in!!! Anyone successfully done this?
« Reply #3 on: 27 August 2004, 13:52 »
I've just bought the gear for doing it as I think I'll be doing Hazels Audi to get it through its next MOT.
I would have thought that if you bring the piston to the top, before you start, it won't fall down so far that you can't get at it :-\
Another idea I have heard is to insert non-fraying rope into the spark plug hole, with the piston down, when you have 'enough' in there, bring the piston up so compressing the rope onto the valve. Worth a thought if you don't have access to a compressor.
GTI-BOY
« Reply #4 on: 27 August 2004, 15:35 »
Now that sounds like a plan!! :D
I'll try that when I get a free weekend , i'll try and get some pics as I go :)
Cheers ;)
« Reply #5 on: 27 August 2004, 15:48 »
Good luck. Yeah, let us know how you get on..........I've never done the job without removing the head before, but deffo intend on trying on Hazels Audi.
Just out of curiosity, if using the compressed air technique, anyone know how you crack the collets loose? Usually with the spring compressor it takes a little initial effort to crack the collets and then its easy to wind the spring down.
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 27 August 2004, 17:32 »
my 8v use to do that randomly. I'd just flew past Vix once and it puffed out a cloud ;D
Mk4 Golf 150PD
Offline mk1
« Reply #7 on: 27 August 2004, 18:52 »
If you are using the compressed air method, put a socket on the top of the collet retainer and give it a sharp whack with a hammer. That usually breaks the collets free and you should have no problem compressing the spring and retrieving them. Don't do what I did once and switch off the compressor, came out of the house later to find the valve had dropped down into the cylinder >:.( Oh well, had a full head set anyhow :-\).
Steve.
« Reply #8 on: 28 August 2004, 18:47 »
Cheers Steve. Out of curiosity, when that valve dropped, did you have your piston at TDC? Just wondering, had it been at TDC, whether you might have been able to pull it back up again without taking the head off :-\
Offline mk1
« Reply #9 on: 28 August 2004, 19:59 »
Tdc, as when you pressurise the cylinder it will go down to bottom dead centre ::). If you use the string method I would look into some way of locking the crank as it will want to roll over from tdc when you press down on the valve. Let me know how it goes with Hazels car.
Steve.
« Last Edit: 28 August 2004, 20:05 by mk1 »
