Golf mk3
hardmonkeys
Revs take ages to drop when warm
Topic: Revs take ages to drop when warm (Read 718 times)
leegt5
12 July 2009, 21:21 »
I have just replaced my throttle body as the old one would keep clicking and adjusting itself when the ignition was on and it would cut out after start up unless the revs were kept up for the first 2 minutes.
Now with the new one it starts on the button from cold and doesn't cut out. However once its warmed up when I dip the clutch to change gear the revs drop really really slowly. Ive tried 2 other throttle bodies and it does the same.
So is that how they are normally but mine dropped quickly before (with old throttle body) because it was faulty or another fault could cause the revs to drop slowly ??
Support London's Air Ambulance
johnson6672
Re: Revs take ages to drop when warm
13 July 2009, 09:35 »
I know on the Mk4 once you have done a throttle body clean it takes a while for the idle to settle down to normal, usually a few hundred miles, might be worth leaving it on and give it a couple of hundred miles.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Golf mk3
hardmonkeys
