Author Topic: NUTS!!!!!!!!!!  (Read 1522 times)
Offline harlemex
NUTS!!!!!!!!!!
« on: 12 July 2009, 20:42 »
You lot should definately be able to help me out here seeing as alot of you have done your shockers. Where can I get the three nuts that go on the top of the rears? I suspect there are different types for different makes. Mine are standard boges. Cheers.
ianw3321
Re: NUTS!!!!!!!!!!
« Reply #1 on: 12 July 2009, 20:44 »
Scrappy
Offline harlemex
Re: NUTS!!!!!!!!!!
« Reply #2 on: 12 July 2009, 20:58 »
good idea, but there must be somewhere i can get them new for cheap seeing as it is a common replacement part.??
Offline funkyfive
Re: NUTS!!!!!!!!!!
« Reply #3 on: 12 July 2009, 21:07 »
I would contact your local vw garage tbh.
Offline harlemex
Re: NUTS!!!!!!!!!!
« Reply #4 on: 12 July 2009, 21:12 »
i went to vw but they could not confirm what thread size there nuts are, and they dont have any on the shelf. I require super fine thread pitch, the ones on my old shocks are a coarse thread. :sick:
Offline DrewGTI
Re: NUTS!!!!!!!!!!
« Reply #5 on: 12 July 2009, 21:19 »
surely if they ordered the nuts you need they will be the right size if standard?
Offline harlemex
Re: NUTS!!!!!!!!!!
« Reply #6 on: 12 July 2009, 21:22 »
thats what i thought but they arent vw shocks, thy are boge's.
Offline DrewGTI
Re: NUTS!!!!!!!!!!
« Reply #7 on: 12 July 2009, 21:28 »
ah get ya. . .
trip to the good old scrappy.  :smiley:
Offline boneybradley
  • Back in a Mk3...
Re: NUTS!!!!!!!!!!
« Reply #8 on: 12 July 2009, 21:37 »
go to a nut and bolt place with a shocker and buy some (nylon) lock nuts....I've used them loads of times in the past
Re: NUTS!!!!!!!!!!
« Reply #9 on: 12 July 2009, 22:00 »
Should be supplied with the shocks, if not try a nut / bolt suppliers
