Author Topic: quick question  (Read 2113 times)
Offline stevo211
quick question
« on: 12 July 2009, 19:26 »
hey all ive had my mk3 8v gti for 2 weeks and i did the timing belt today and took it out for its first blast and it redlined at 5k, i just wondered if thats how they are or have i got the timing out (probably a silly question) ive never done a belt on one of these before. and is the big pulley to the right is what im assuming is the ignition timing?
Offline Agreeable Slick
  • Unit
Re: quick question
« Reply #1 on: 12 July 2009, 19:37 »
Timing is out prob by a tooth or so.
Oh and do a search, this question has been asked loads.  :smiley:
Offline stevo211
Re: quick question
« Reply #2 on: 12 July 2009, 19:50 »
i mean it runs mint no splutters or anything but what do they normally hit the limiter at i dont beat the sh!t out of my cars but i noticed it wasent as quick
  • Unit
Re: quick question
« Reply #3 on: 12 July 2009, 19:55 »
http://www.golfgtiforum.co.uk/index.php?topic=67922.0
Searching comes up with the above. Try it here: http://www.golfgtiforum.co.uk/index.php?action=search
Also, if the engine has detected this, it will kick over to safe mode to limit engine damage. Get timing checked then get the codes cleared off the ECU.
Offline Khare
  • The bear that khares
Re: quick question
« Reply #4 on: 12 July 2009, 19:55 »
the ECU is in safe mode because the timing is out. Recheck everything lines up with everything, usually its only out by a tooth or two.
Offline stevo211
Re: quick question
« Reply #5 on: 12 July 2009, 20:08 »
how do you reset the codes
thanx for the help too
Re: quick question
« Reply #6 on: 12 July 2009, 21:51 »
The cam timing should be set with the edge of the head and not the cover, I believe disconnecting and leavin the battery off for 30mins will clear it.
Offline stevo211
Re: quick question
« Reply #7 on: 15 July 2009, 19:30 »
hi i forgot to mention i ran it for a couple of mins while the airfilter was off could that cause it to go into safemode?
Offline Adam
Re: quick question
« Reply #8 on: 15 July 2009, 21:01 »
You have not timed it up properly.
Down Hill From Here.
Offline stevo211
Re: quick question
« Reply #9 on: 16 July 2009, 07:30 »
thanx for the help guys, do i need to take the ign timing pulley off to get the water pump off? or will it come off around it
