Author Topic: Mk1 9a driveshaft ?  (Read 2767 times)
Offline bulletz
Mk1 9a driveshaft ?
« on: 12 July 2009, 04:12 »
I've read a lot of info regarding the use of different driveshafts eg: 90mm or 100mm when doing a mk1 9a swap.
I am using a 020 box, 90mm driveshaft flanges but after taking the car for its first short run i've noticed that the drivers side drivshaft is too short, t has popped out, any idea on what one I should be using??
Re: Mk1 9a driveshaft ?
« Reply #1 on: 13 July 2009, 09:12 »
you use MK1 chassis shafts, matched to the gearbox. so if 90mm flanges you want MK1 GTI 90mm shafts, if 100mm flanges you want late MK1 cabrio/scirocco 100mm shafts
Offline bulletz
« Reply #2 on: 13 July 2009, 10:13 »
so are the mk1 GTI shafts longer than the non GTI ones????
Offline danny_p
« Reply #3 on: 13 July 2009, 10:45 »
small block shafts from 084 and 085 boxes are diffrent lengths than shafts from 020 boxes
all the VW's have gone bar 1.
« Reply #4 on: 13 July 2009, 11:30 »
as above, 1.0-1.3 shafts need replacing with manual 1.5-1.8 MK1 Golf/Scirocco/Cabby ones to match the gearbox you have
Offline Meatpie
« Reply #5 on: 13 July 2009, 12:58 »
I had an issue with the shaft for my sportline, had a gearbox from a non-gti but as the shaft length was wrong, it kept eating CV joints :s
hopefully you dont have the same problem :)
Offline bulletz
« Reply #6 on: 22 July 2009, 11:06 »
I'm a twit!!.....driveshaft is fine, the damn circlip had popped off for some reason  :huh:
