Author Topic: Growly 8v??  (Read 1836 times)
Speedydub
Growly 8v??
« on: 26 August 2004, 12:23 »
Is it possible to drill the airbox on an 8v, so it sounds lush???
N where do u drill??
 :P
Offline Gambit
Re: Growly 8v??
« Reply #1 on: 26 August 2004, 12:31 »
is it a k-jet or digifart airbox?
Speedydub
Re: Growly 8v??
« Reply #2 on: 26 August 2004, 12:32 »
k jet  :D
Offline Gambit
Re: Growly 8v??
« Reply #3 on: 26 August 2004, 14:00 »
take the base of the airbox out as its easier to work with out of the car!
remove the inner panel from the box and then drill the wing side, or just cut a hole in the wing side!!
Offline Dizzie
  • Make friends with your fast
Re: Growly 8v??
« Reply #4 on: 26 August 2004, 14:04 »
don't drill the engine side. hot air is bad mmmkay.
Speedydub
Re: Growly 8v??
« Reply #5 on: 26 August 2004, 18:41 »
lush  8)
Offline knobby
Re: Growly 8v??
« Reply #6 on: 26 August 2004, 23:23 »
ive cut whole all over mine and just put a cold air feed to it... Sounds sweet.. Not jon boy like.. BIG engine like!!
Old VW's never die...they just go faster!
Speedydub
Re: Growly 8v??
« Reply #7 on: 27 August 2004, 08:56 »
cold air feed????
Offline Dizzie
Re: Growly 8v??
« Reply #8 on: 27 August 2004, 09:35 »
Cold Air Feed n a pipe that comes off the front of the car into the air box to 'feed' air
;D
