Author Topic: Speedo has stopped  (Read 1293 times)
Offline Martz
Speedo has stopped
« on: 26 August 2004, 08:45 »
on my way to work. Its a loose connection (I know that coz I put in in incorrectly). Its a barsteward to get the clocks in.
Any tips on not smashing it up in a rage of temper?
Offline Deefadog
  • Mk2 16V (November 89)
Re: Speedo has stopped
« Reply #1 on: 26 August 2004, 12:49 »
Prozac :) (I think that's the spelling)  :D
Offline MarkII16v
« Reply #2 on: 07 September 2004, 09:48 »
If you're lucky then the speedo cable may still be lined up with the back of the clocks, mine did this so every now and then the needle would go mad then stop working.
Simple technique I used was to pop the bonnet, find the speedo cable where it passes thru the bulkhead and gently push it thru more. The cable is strong enuff not to bend so it simply clipped itself back on and its been working fine ever since.  ;D
This'll only work if the connectors are still touching though as otherwise you'll just push the cable past the connector and against the back of the clocks  : :-\
Offline benjam_in
« Reply #3 on: 07 September 2004, 12:47 »
i tried that technique! but failed! so resorted to the proper way! can take a dash apart reconnect the speedo and put it back together in about 15 mins now!
Golf Mk2 Gti 1988
