Author Topic: A Little Help With Lighting...  (Read 3163 times)
Offline JMallows
« on: 25 August 2004, 23:57 »
There is a problem with my lights, and i don't know where to begin looking. Switch on dipped beam, fine except for the spots are glowing, really dim, but just about on. Turn om high beam, fine on most occasions, sometimes only the left hand side lights up, the right is just sidelights. Switch off high beam, no light whatsoever, then real slowly the dipped beam "fades" back in. The same way the sidelights come on with the dim dip system. Its as though the lights \re controlled by the dim dip, but they can't be! HAve tried unplugging the dim dip connectr to no avail. The only thing i did notice was a relay going mad in the fusebox every now and again. Took off the cover to determine which it was (typically stopped clicking!) The relay in the bottom row, second from left was very hot (relay number 17, i think in location 8) so i thought it was that relay, but the one above that was doing the clicking (relay number 1 location 2). I didn't think the lights were relay controlled? In the haynes manual, it says relay location 8 is the relief relay for the X contact. I think this may have something to do with the lights, in the wiring diagram for the light switch, it goes throgh a relay, to a line marked X, is the same X? And why is the relay above clicking so randomly. Also, should the relay get hot in operation? Could it be a short somewhere?
A clever person solves a problem. A wise person avoids it.
Offline Dizzie
  • Make friends with your fast
Re: A Little Help With Lighting...
« Reply #1 on: 26 August 2004, 00:42 »
have you tried changing the switch and relay?
Offline JMallows
« Reply #2 on: 26 August 2004, 10:56 »
I'm going to try getting two new relays today. Do you mean the switch attatched to the wiper stalk? I took it apart, couldn't see anything wrong with it... I did replace a little while ago cos the wipers kept fusing due to the switch being broken, so i do have a new switch.
« Reply #3 on: 26 August 2004, 16:09 »
Have you tried changing the switch on the dash as well?
Offline JMallows
« Reply #4 on: 27 August 2004, 11:22 »
Welll, i relpaced the two relays, to no effect ?:(
What, the switch to turn on sidelights/headlights? No, i haven't. Won't do much though will it? ???? I did also try unplugging the dim dip thing, but it didn't help either. I really don't want to have to take it into the garage...
Offline Gambit
« Reply #5 on: 27 August 2004, 11:34 »
sounds more like a bad earth to me
Offline JMallows
« Reply #6 on: 27 August 2004, 11:51 »
That was one thing i had thought of... But i don't where the Earths are for the lights? I'm assuming its an earth for each side, as only the left works?
dub855
« Reply #7 on: 30 August 2004, 20:34 »
i got a simlar/weird problem.
When i have just side lights on, the dipped as you say fades in and remains on.
Haven't got a clue whats causing it, so have just learned not to have just side lights on lol. More noticable on mine with the rallye front.
If have get an answer please let me know!
Luke
Offline JMallows
« Reply #8 on: 01 September 2004, 20:01 »
Luke
Yeah, sure thing. Surely someone must have an idea about this. A few people I've asked have said have said earth fault. I don't know where the Earthing points are though, someone must be able to help with that?  ???  :-\ But, if it is a faulty earth, then surely this would affect other systems??
Veedubgt18v
« Reply #9 on: 01 September 2004, 20:08 »
Quote
these become worn internally or the wiring plug can become bad resulting in poor connections. cut the wiring plug off the back of the dash switch and use spade connectors to redo all the wiring connections to the switch, see if that works before you spend loadsa dosh
