Golf mk3
hardmonkeys
ECU
Topic: ECU (Read 753 times)
paul73
ECU
10 July 2009, 21:12 »
Hi, just a quick one, how do you remove the plug from the ecu without breaking it please?
Khare
Serious forum addict
The bear that khares
Re: ECU
10 July 2009, 21:13 »
it should slide to one side, then just pull it out gently.
paul73
Re: ECU
10 July 2009, 21:16 »
You just pull it at 90 degrees and then it comes off??
Khare
Re: ECU
10 July 2009, 21:18 »
huh?
no there is a pin, within the plug, it should slide all the way out, and then just pull the plug off the ECU.
Golf mk3
hardmonkeys
ECU
