Author Topic: 16891 - Idle Control System RPM Higher than Expected.  (Read 2305 times)
Offline Philpy
Missus has just come home and said engine management light is on.
Plugged the laptop in and got the above.
The engine is making a hissing sound and when you push the pipes going to the idle valve it stops the hissing.
Gonna have a look tomorrow. Anyone had anything like this before?
Offline Steve_PD
Re: 16891 - Idle Control System RPM Higher than Expected.
« Reply #1 on: 10 July 2009, 18:03 »
not had it but wiki says
  16891/P0507/001287 - Idle Control System RPM: Higher than Expected.
Possible Symptoms
    * Malfunction Indicator Lamp (MIL) active
Possible Causes
    * Throttle Valve Control Module (J338) dirty/faulty
    * Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Possible Solutions
    * Check Throttle Valve Control Module (J338)
    * Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
