Golf mk3
hardmonkeys
ABS LED Bulb
Topic: ABS LED Bulb (Read 1668 times)
Asbo Sovfinger
GTI forum regular
I drink your milkshake!!
ABS LED Bulb
10 July 2009, 17:41 »
Hey all,
Anyone know what LED is need for the ABS light? The bulb in mine appears to have been crushed so needs replacing.
Cheers, Ed
'06 Ford Mondeo ST TDCi estate - Machine Silver with full leather Recaro interior (Black)
Adam
Forum addict
Re: ABS LED Bulb
10 July 2009, 18:25 »
Thats the start of bad things, someone has crushed it for a reason...i.e ABS light is on.
Good luck with that,
Down Hill From Here.
funkyfive
Re: ABS LED Bulb
10 July 2009, 19:54 »
Sounds like the same problem i had, i got a new unit from a breakers yard for 8 quid.
doely85
GTI forum regular
Re: ABS LED Bulb
11 July 2009, 15:50 »
its easier to replace the unit, take the old unit out and it will have a part number on the side, type that into ebay and some should come up, got one last week for a tenner
adamrob69
Guest
Re: ABS LED Bulb
11 July 2009, 16:23 »
my bulb has actually blown for some reason, you carnt change the bulb on its own as its attached to its housing which is soldered to the board. best bet is as said change the whole unit, unless you have your own LEDs lying about and a solder iron
ianw3321
Guest
Re: ABS LED Bulb
12 July 2009, 16:26 »
My abs light does not come on at all. Do you think I need one of these also?
funkyfive
Re: ABS LED Bulb
Reply #6 on:
12 July 2009, 19:06 »
http://cgi.ebay.co.uk/GOLF-MK3-GTI-16V-VR6-HIGHLINE-ABS-AIRBAG-LAMP-LIGHT_W0QQitemZ160347207204QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2555703624&_trksid=p3286.c0.m14&_trkparms=65%3A12
|66%3A2|39%3A1|72%3A1689|293%3A3|294%3A50
Cheap with no bids
ianw3321
Guest
Re: ABS LED Bulb
Reply #7 on:
13 July 2009, 12:15 »
How do you get this little panel off? Prise with a screwdriver?
funkyfive
Re: ABS LED Bulb
Reply #8 on:
13 July 2009, 12:51 »
Yes mate, i used a fine flat head.
Golf mk3
hardmonkeys
ABS LED Bulb
