Author Topic: full service  (Read 1154 times)
Offline omex_uk
full service
« on: 10 July 2009, 13:38 »
i just brought a gti with 83k on the clock. no history other then a few mot's so i decided im going to give it a full server after hours at my mates garage.
im going to change;
¬sparks
¬water pump
¬gear box and engine oil
¬cam belt
¬fan belt
¬cam (buying a piper uprated one)
¬valves
and im going to get the head pressure tested and skimmed
what i want to know is there anything im missing out ? anything that are notorious for giving problems on mk3s that arnt on the list?
cheers lads
Offline Adam
Re: full service
« Reply #1 on: 10 July 2009, 13:43 »
Port and Polish
Down Hill From Here.
Offline DubSociety
Re: full service
« Reply #2 on: 10 July 2009, 13:47 »
fuel filter
dizzy & rotor arm
both cheap bits to replace
Offline Adam
Re: full service
« Reply #3 on: 10 July 2009, 13:49 »
ECU and Fuel relay
Water temp sensor
Offline DubSociety
Re: full service
« Reply #4 on: 10 July 2009, 13:50 »
Also check to see the condition of the crank sensor while its on a ramp ... mine was knackered (the wire was split etc and covered in oil from an engine leak) and caused my car to keep cutting out. After numerous suggestions from friends & people on the forum, and £1000 later ... (changed EVERYTHING, including purchasing new ECU and Resetting at VW etc) I then changed the crank sensor and it solved the problem.
Offline Horney
Re: full service
« Reply #5 on: 10 July 2009, 14:08 »
Full brake fluid change.
nick
Offline omex_uk
Re: full service
« Reply #6 on: 10 July 2009, 14:39 »
lol damn this is going to cost me more then my 250 estimate  :grin:
