Author Topic: Manual or DSG?  (Read 172901 times)
Offline matchboy
Re: Manual or DSG?
« Reply #140 on: 26 August 2009, 17:04 »
[/quote]
...not how some goon in a cheap suit and plastic shoes decides I should drive.
[/quote]
 :grin:
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline rjwojcik
Re: Manual or DSG?
« Reply #141 on: 26 August 2009, 17:22 »
Can you get a remap for the DSG?  I'm sure I've seen people talking about these things elsewhere, they seemed to mention you could then have it hold onto the gear and not change up near the rev limit.]
Maybe...but you shouldn't have to buy a new car and immediately start putting right the wrongs...it should be just so from new. With manual, it is.
But then you could also use the same arguement about the engine, why chip it (but people do)?  I would have thought engine, gearbox and other systems in modern cars have a margin of safety and tolerance built in, all you're doing is changing it to behave they way you prefer (and reducing the margins). :huh:
Current:
2018 RS4  - Navarra Blue / Black
Gone:
2016 A6 BiTDI - Midnight Blue / Black
2016 Golf GTD with a "lot" of toys
2016 M3 CP - Mineral Grey / Black
2009 135i - Le Mans Blue / Black
Offline Ess_Three
Re: Manual or DSG?
« Reply #142 on: 26 August 2009, 17:35 »
Indeed you could..
But you'd chip it to give you more of what you want...not completely change the function, just do more of what it does anyway.
Same for fitting big brakes...
But with DSG you'd have to completely change it's operation...which would involve removing it and fitting a 6 speed manual with a gear lever, in order to make me happy with it.
No matter, I went in with an open mind...and came out with a very firm opinion.
Manual it is.
..but gaining motorcycles.
Offline S2000_Europe
Re: Manual or DSG?
« Reply #143 on: 27 August 2009, 16:30 »
You mean the same 'official' 0-60 of 7.2 when it was being tested at nearly a second quicker  :rolleyes:
Writing fact at the end proves nothing mate, DSG is more economical, it is always in the optimum gear for the revs which uses as little power as possible when in D and driving slowly.
I just posted up the stats for you to see!
I think we can agree to disagree on this one.
Have VW got their figures wrong?
There is and article on EVO Magazine, July issue I think, arguing about the Co2 and fuel Economy figures of Automatic cars.
In summary, Car markers cheat using gearboxes map for gear selection that manual car can not copy because the car would stall. I will try to scan the article and post it here
I am still deating fi manual o DSG. I the future maybe I will do a remap, a mkVI and it seems that DSG can not hold to much torque, 280Nm is the limit?
Honda S2000 MY02:
Volks Ce28 17x7.5 & 17x9 with Michelin Sport Cup, Cusco Chasis subframe,
Hardtop, Softtop detached,
Mugen titanium Exhaust,
J'racing Hearder & Carbon Intake, 2.2L Stroker kit
2 Piece front rotors
Mk5 o Mk6 in the near future
Jkctr
Re: Manual or DSG?
« Reply #144 on: 27 August 2009, 20:04 »
Hurdy and jonnyc have ALOT more torque than that  :laugh:
Offline Max Q
Re: Manual or DSG?
« Reply #145 on: 27 August 2009, 20:20 »
In 'manual' it still changed up when it wanted to...not when I did.
It will only change up above redline to protect the engine - that's the only instance in which it will change up in manual. Did you redline it? If not, then are you sure you were in manual (i.e. shifter in the gate to the left of D), or just the temporary manual takeover when you start shifting with the paddles with the shifter still in D? In the manaul takeover mode it reverts to auto after 30s of non-use of the paddles, and so might change up in this case.
Mk7.5 R DSG Indium Grey 5Dr
Jkctr
Re: Manual or DSG?
« Reply #146 on: 27 August 2009, 20:36 »
It will drop down in manual if you hit the 'kick' button too
Offline Ess_Three
Re: Manual or DSG?
« Reply #147 on: 28 August 2009, 10:12 »
I did, and it changed up...not that I'm in the habit of sitting on the limiter, but on the track, there is a regular instance where I have done in the past, to avoid a up, immediate down change...I wanted to know it would do it, as a manual will...and it won't.
Quote
Accross the gate for sure....I got fed up with the ECU taking over and reverting back in temporary manual takeover.
Offline Ess_Three
Re: Manual or DSG?
« Reply #148 on: 28 August 2009, 10:14 »
I didn't like that either...
I had already decided 4th would be fine, as I'd dropped two gears (at the speed 'it' wanted too, not the speed I wanted it to!) but oh no, DSG wanted 3rd...
The result was manic revving and much cursing...
4th and full throttle would have been just fine.
Offline R32UK
Re: Manual or DSG?
« Reply #149 on: 28 August 2009, 10:21 »
try it in an R32 mate.. scares the crap out of anyone stood within 10ft of you!!  :laugh:
