Author Topic: Rear brake pad problems.  (Read 1528 times)
ianw3321
« on: 09 July 2009, 12:06 »
I tried to fit new pads today in my 1995 8v gti, but cannot get the piston in the caliper to move back. I have tried screwing the piston in both directions and I have tried levering the piston all to no avail indeed the piston has actually moved a bit farward and I cant even get the old pads back in. Any suggestions will be welcomed as I have no brakes.
Offline Adam
Down Hill From Here.
Offline BlazinGTI
Re: Rear brake pad problems.
« Reply #2 on: 09 July 2009, 16:46 »
well worth every penny that tool!!!!
you can do it with some external circlip plyers (reccomended in the haynes) but what a pig!!!! 4 hours it took me!
ianw3321
« Reply #3 on: 09 July 2009, 17:25 »
I have managed to get it back in by removing the piston altogether, emptying the brake fluid out of the cylinder, then reinserting the piston and alternately twiisting and tapping ok hitting it with a hammer,then finally bleeding that caliper to get rid of the air.
Offline tweed
« Reply #4 on: 10 July 2009, 15:25 »
Took me longer to get the pads in, than screwing the piston in with the right tool  :wink:
Offline omex_uk
« Reply #5 on: 10 July 2009, 15:55 »
lol your all a bunch of women. ive used a large pipe wrench to push it in the last 3 times ive done brakes on different cars
Offline Adam
« Reply #6 on: 10 July 2009, 16:41 »
I thought that could dammage it  :huh:
Offline omex_uk
« Reply #7 on: 10 July 2009, 17:10 »
nope its what my mechanic mates does at his work and its what they taught him to do on the corse he took a few years back
ianw3321
« Reply #8 on: 10 July 2009, 18:50 »
You can use a big lever with front discs/pads as they are self adjusting but rear discs/ pads need manual adjustment by screwing the piston as it is attached to the handbrake mechanism. You also need to adjust as the pads as they wear just like shoes or you end up with excessive pedal travel.
