General discussion
pulstar pulse plugs
Topic: pulstar pulse plugs (Read 1576 times)
james2
No scammers please.
pulstar pulse plugs
08 July 2009, 09:46 »
Is this right the gap are suppoed to be 0.045mm i was told by a seller i got the plugs from as i set them to 0.08mm and they faild
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
james2
No scammers please.
Re: pulstar pulse plugs
08 July 2009, 10:13 »
There for a 1.8 turbo agu engine
spunkymonkey
Tepidly moist! That's what that is!
08 July 2009, 16:52 »
0.08? Thants nearly closed. Do you not mean 0.8? Thats what i would have set them to.
james2
No scammers please.
08 July 2009, 16:57 »
yer sorry 0.8mm same as the plugs that came out but have been told they should be 0.45mm they are confusing me like hell in the leaflet that came with them says 0.030"
Phil18t
GTI forum regular
08 July 2009, 21:58 »
as above, id set them to 0.80mm.
DOA
08 July 2009, 22:19 »
30 thou is 0.762mm so 0.8mm is right or thereabouts. You can use them at 0.45 but its not what you would call ideal for a roadgoing turbo engine, more for a racer thats at full chat all the time (or they will foul).
james2
No scammers please.
Reply #6 on:
09 July 2009, 09:57 »
Thanks for the help manged to get the bloke to take them back and see what happened ill let you lot know
General discussion
pulstar pulse plugs
