Author Topic: ECU reset?  (Read 1553 times)
Offline ILOVEMY8V
ECU reset?
« on: 25 August 2004, 11:30 »
Last week I disconnected the battery on my 8V digi for 2 hours when I removed the dash to change bulbs. Since then the MPG figure has dropped on the MFA from an average of about 30 to 21 & have confirmed it is lower by the amount of petrol going in. I once heard that the ECU resets to factory deafults when the battery is disconnected for more than 15 minutes. Is this true? If so, how do I get the settings back to what they were?  Any comments & ideas greatly appreciated.
Offline Dizzie
  • Make friends with your fast
Re: ECU reset?
« Reply #1 on: 25 August 2004, 15:30 »
the MPG reading comes from a vacume pipe off the inlet manifold. the ecu has nothing to do with it afaik. you've probably got a small leak somewhere caused when you removed part of the dash.
