Golf mk4
Golf mk4 TDI
Wazzzer
Brake Pad Indicator
Topic: Brake Pad Indicator (Read 2524 times)
EuanGtTdi
Brake Pad Indicator
07 July 2009, 20:01 »
Hi guys,
my brake pad wear warning sign on the dash computer keeps coming up then going off,
like has it own mind! it got new discs and pads put on about 5 months ago!
Think the sensor is maybe goofed or is this about right fo pads going?
Euan
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
Re: Brake Pad Indicator
07 July 2009, 20:06 »
Might be a loose plug, check that it is fully pushed in
old_n07
08 July 2009, 08:52 »
It could also be that a wire has rubbed through on the insulation and it intermitantly grounding on the bodywork \ suspension.
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ
Miles to Empty Guide
EuanGtTdi
08 July 2009, 17:12 »
the brake wear sensor cable a wire has rubberd through so going to have to get new one
Golf mk4
Golf mk4 TDI
Wazzzer
Brake Pad Indicator
