Author Topic: Need urgent help!!  (Read 3081 times)
Offline Devilz
  • Cruisin is not a crime
Re: Need urgent help!!
« Reply #20 on: 09 July 2009, 12:56 »
did you clear the code and then re-scan??
no i didn't, how can i clear the code before re-scan?
should be a button called Clear DTC or soemthing similar - click that and then rescan and with a bit of luck your code should disappear
i'm running vag-com 311.2-N and on main screen i got these buttons
select
auto-scan (i used this one to scan for error codes)
control module finder
OBD-II
Options
About
Exit
i've checked all options but couldn't found anything relating to clear codes, do u know where to find id rhyso?
Offline Rhyso
« Reply #21 on: 09 July 2009, 12:58 »
you need to do the following
select
then click the correct module - it will either come under Engine 01 or instruments 17
Fault codes
Clear DTC
Offline Devilz
« Reply #22 on: 09 July 2009, 13:29 »
thanks rhyso, i cleared the codes and re-scan my car, fault is gone now.
i really hope it will sort my fuel consumption problem
Offline Rhyso
« Reply #23 on: 09 July 2009, 13:33 »
good stuff
fingers crossed it will do the trick - it most likely will do  :smiley:
Offline Devilz
« Reply #24 on: 09 July 2009, 13:50 »
good stuff
Now its done, what sort of mileage i should be getting now ?
Offline Rhyso
« Reply #25 on: 09 July 2009, 13:52 »
good stuff
no idea - i drive a diesel remember  :wink:
Offline Devilz
« Reply #26 on: 09 July 2009, 13:54 »
yeah i remember, cheers man for your help
+1  :laugh:
problem solved, topic locked
