Author Topic: Need urgent help!!  (Read 3074 times)
Offline navmk4gti
Re: Need urgent help!!
« Reply #10 on: 07 July 2009, 22:51 »
are you running vista regarding the vag com?
Offline Devilz
  • Cruisin is not a crime
« Reply #11 on: 07 July 2009, 23:10 »
no, i'm running xp
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 08 July 2009, 17:20 »
the temp sender tells the ECU how much fuel to put in depending on engine water temp (think of it as a choke)
so if that is knackered it will tell it to throw fuel in for fun
contact me via PM for help regarding VAG COM  :wink:
Offline rheady
« Reply #13 on: 08 July 2009, 19:59 »
Temp sender  A059 919 501 A  £25.90
Retaining clip A032 121 142   £0.41
O ring          AN 903 168 02   £0.94
These are for a AUM engine, green sender. These prices are without VAT. 5 minute job to do.
Offline navmk4gti
« Reply #14 on: 08 July 2009, 23:26 »
if you got a AGU it is a blue sender you want
Offline richw911
« Reply #15 on: 08 July 2009, 23:41 »
Blue is the old type However my AGU uses the green  :nerd: :wink:
http://www.golfgtiforum.co.uk/index.php?topic=88088.0
« Last Edit: 08 July 2009, 23:47 by richw911 »
Offline Devilz
« Reply #16 on: 09 July 2009, 12:44 »
alright my friends, i just changed temp sender and ran vag-com afterwards and i'm still getting same errors
VAG-COM Version: Release  311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01     -------------------------------------------------------
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-10 - - - Intermittent
Readiness: N/A
now what to do? I just lost £31.00 for no reason  :cry:
Offline Rhyso
« Reply #17 on: 09 July 2009, 12:48 »
did you clear the code and then re-scan??
Offline Devilz
« Reply #18 on: 09 July 2009, 12:50 »
no i didn't, how can i clear the code before re-scan?
Offline Rhyso
« Reply #19 on: 09 July 2009, 12:52 »
should be a button called Clear DTC or soemthing similar - click that and then rescan and with a bit of luck your code should disappear
