Author Topic: Front brake noise - sorted!  (Read 3401 times)
Offline Mr_Orange
« on: 07 July 2009, 18:18 »
It's come back again!
chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-chirp-
Getting very annoying now!
Changes with wheel speed (gets faster / slower).  Noise changes slightly under very light braking and goes away fully under normal braking.  Seems to also go quiet when I steer left?  Then always comes back again.  Not noticeable from cold, but after a few miles is present down to 10/15 mph.  On way home tonight it wasn't there until I applied brakes on m.way then it was there all the way back!  :(
Back in the garage for this tomorrow.... again
What am I looking at?  Sticky caliper?  Warped disc?  Dodgy hub/bearing?  Help!
« Last Edit: 28 August 2009, 10:22 by Mr_Orange »
Build thread clicky
Offline spetzdude
  • I Bleed Blue!
Re: Front brake noise
« Reply #1 on: 07 July 2009, 18:23 »
have you recently changed the pads or disks?
the pads could not be aligned properly?
worn out pads?
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline Mr_Orange
« Reply #2 on: 07 July 2009, 18:38 »
worn out pads?
Had the same noise before, changed the discs, but its come back again.
Noise is intermittent so it must be related to wheel rotation and the brakes rubbing.
The pad would be a constant noise no?
Only came on again tonight after a few miles and after applying the brakes.
Pad stuck out rubbing on disc (possibly warped again) due to sticky caliper?
Build thread clicky
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 07 July 2009, 18:39 »
have you jacked the front up and given the wheel a shake to check the bearing?
Offline spetzdude
  • I Bleed Blue!
« Reply #4 on: 07 July 2009, 18:41 »
"The pad would be a constant noise no?"
No becasue it would be rubbing on the disk.
best thing to do is what topher said and wile your doing that have a good look around and spin the wheel, if you still cant see anything, take it to a garage where they have ramps, so they can have a good look.
BHP: 231
TRQ: 341.3
Offline rheady
« Reply #5 on: 07 July 2009, 18:54 »
Is the dust shield bent and touching the disc. That could be one option.
Offline Mr_Orange
« Reply #6 on: 07 July 2009, 19:01 »
Sorry dude I know what you are saying.  I meant to say if it were a pad issue (worn, glazed etc) it'd give a constant contact noise on disc under braking etc, which I aint got.  I'm thinking slight disc runout / caliper stuck out, as it chirps slightly with each rotation of the wheel.
Bearing seemed OK when I looked, no play there.  Manually spinning that wheel there was a slight tight spot.
I've also checked temp of wheel and caliper after a good run and no different to other brakes.
I don't want the garage guessing with my money what the problem is, and to go there armed with some idea what to expect.
Build thread clicky
Offline Mr_Orange
« Reply #7 on: 07 July 2009, 19:02 »
Good call.  I'll have a look!
Build thread clicky
Offline Dubbz
« Reply #8 on: 07 July 2009, 21:42 »
I had a noise coming from my N/S/F wheel, it was more a knocking, metal noise, when i went over rough ground i could hear it rattle, sounded like one of the springs was loose.
When i touched the brakes i could hear a clicking noise  :rolleyes:  :undecided:
Anyway i took the wheel of looked at the ARB bushes they're a little worn, but not major worn.
I took the calliper off and the rear pad anti rattle clip was loose and was moving around in the calliper, bent the clips out a little for a tighter fit and the noise has gone. :afro:
Good luck Mr Orange.
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline mattkh
« Reply #9 on: 07 July 2009, 21:56 »
Help!
Hi
If there is a dust shield at the front behind the disc, then check that it is not catching anywhere.
