Author Topic: 1.8t problem with gears  (Read 1397 times)
Offline crusaderno10
« on: 06 July 2009, 21:04 »
Hi all, just wunderin if any ov u guys cud help ? Ive got a problem getting 3rd gear sometimes, this only seems to happen when Ive been driving for a short while or when I put my foot down.
The gear stick will move into 3rd gear about 90 % of the way but then stops, which then I hav to miss it out or drop it back down to 2nd. All the other gears seem fine and I can get them with no problems and 3rd seems fine when the cars cold.
Also when Im changing into 2nd gear and put my foot back on the accelerator the car will pick up slightly then dwindle before picking up speed again, Cud these problems be linked?
Any advice wud be greatfull, cheers.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: 1.8t problem with gears
« Reply #1 on: 06 July 2009, 21:13 »
Personally, my first port of call would be getting the G/B oil changed, then take it from there.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline spetzdude
  • I Bleed Blue!
« Reply #2 on: 06 July 2009, 21:17 »
and if it aint that my second guess would be the linkige
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline jtomlin
  • 1999 AGU 1.8T GTI
« Reply #3 on: 06 July 2009, 23:54 »
sister had this, after time it will get worse and worse, she cant use 3rd now! i think its the alignment?
« Reply #4 on: 07 July 2009, 20:16 »
Cheers guys on the info much appreciated
Offline opel
« Reply #5 on: 07 July 2009, 20:47 »
so how do u sort the alignment out
