Author Topic: Is there another?  (Read 1664 times)
Offline tg1
Is there another?
« on: 06 July 2009, 13:56 »
I'm looking for a guide on how to fit a t.i.p. Mainly as the t.i.p i have looks a fair bit different to the standard one, but not tried to fit it yet as don't want to ruin anything
Offline tg1
Re: Is there another?
« Reply #1 on: 06 July 2009, 13:57 »
the guide in the maintance section under useful guides/how to's doesn't work
Offline Waffs1984
  • Spacers are for chumps...
« Reply #2 on: 06 July 2009, 14:00 »
"Looks different to the standard one" - in what way?
I must say a guide is always useful (especially with pics) but the TIP is fairly straightforward, just make sure you know where everything connects to (take some pics on a digi camera or do a little sketch) so it all goes back in the same place on refitting.
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline Rhyso
« Reply #3 on: 06 July 2009, 14:12 »
you need to remove both the plastic and metal piece (i assume thats what you mean by different)
hmm not sure what happened to the how-to link
I'm sure Rich will dig up another from somewhere :afro:
Offline Rhyso
« Reply #5 on: 06 July 2009, 15:46 »
i know which pipe it is - what i'm saying is its in 2 parts hence why i said you need to remove the plastic and metal part; the metal part is connected directly to the turbo
also i assume you've bought the correct one for your engine code as there are at least 2 different types - one fits the Ko3 and the other fits the KO3s.  The Ko3s may require a blanking plug for one of the ports
Offline tg1
« Reply #6 on: 06 July 2009, 16:03 »
it said 1.8t, assumed it was one piece for all 1.8t's.
Dammit.
Might actually fit if i take that metal pipe off - maybe i should of looked properly first  :embarassed:
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 06 July 2009, 16:06 »
its fairly straightforward, only advice i would give is the little pipe that plugs in near the very bottom of the TIP by the turbo.. attach that BEFORE you feed the pipe down the engine and attach it to the turbo inlet flange, otherwise it's a bit fiddly to get to.
As i've said before I reckon even a complete novice can do this in 2-3 hours if you use ramps.
Offline Rhyso
« Reply #8 on: 06 July 2009, 16:07 »
Dammit.
two different types for the two different turbo's i'm afraid mate  :sad:  it might fit, might not  :undecided:
yeah take the metal pipe off and it all should become clear  :smiley:
Offline richw911
« Reply #9 on: 06 July 2009, 19:06 »
Link now updated  :wink: :afro:
http://www.ottawa-vdubbing.com/forums/phpBB3/viewtopic.php?f=22&t=8651
