Author Topic: suspected boost leak??  (Read 3202 times)
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
« on: 06 July 2009, 11:41 »
Feels like I've got a boost leak   :undecided: I'm getting some surging at mid revs when WOT.
Are there any common weakspots / pipes to check?
BTW, I've has my bypass valve checked recently, so this should rule this out?
Running Bluefin stg2 & upgraded forge hoses.
Ta in advance.
Offline Hurdy
Re: suspected boost leak??
« Reply #1 on: 06 July 2009, 12:37 »
You need access to VAG COM to do some logging. Do you have it or know anyone near who does?
Seat Leon Cupra Black 290 DSG
Offline Ed30DSG
« Reply #2 on: 06 July 2009, 13:38 »
Yup, I've got access to vag-com, but that won't tell me which pipes are prone to splitting etc.., just confirm that I've got a leak (my butt dyno has been finely tuned over the years on turbo cars LOL!)
Offline bacillus
« Reply #3 on: 06 July 2009, 14:28 »
The usual suspects are the IC hoses!
Also as you have the forge hoses, did you transfer the O rings on the oem couplers on to the Forge couplers?
Additionally don't exclude the DV because you've recently had it checked.
« Last Edit: 06 July 2009, 14:31 by bacillus »
Without traction power is nothing!
Offline Ed30DSG
« Reply #4 on: 06 July 2009, 14:35 »
Thanks, I'll check these first!
Offline RedRobin
« Reply #5 on: 06 July 2009, 14:39 »
There may be some useful info about what else to check in this thread : -
Linky : - Troubleshooting a Boost Leak...
Hope this helps :afro:
Offline Ed30DSG
« Reply #6 on: 06 July 2009, 14:53 »
Some good advice there chaps - thank you for taking the time to post.
Offline robexgti
« Reply #7 on: 06 July 2009, 17:15 »
maybe the DV ( divertor valve ) had it go on mine.
Offline Ed30DSG
« Reply #8 on: 06 July 2009, 18:26 »
I thought the DV was different on the ed 30's?
What were your symptoms??
Offline bacillus
« Reply #9 on: 06 July 2009, 19:29 »
Different physical position to the standard GTi but unless you somehow have the latest version DV, it's still prone to tear...
