Author Topic: breather pipe  (Read 1181 times)
Offline shepgti
breather pipe
« on: 05 July 2009, 11:44 »
quick question, my breather is split and ive got a couple of those breather filters lying about so was wondering if i could fit 1 of these to each end instead of a new pipe?
Re: breather pipe
« Reply #1 on: 05 July 2009, 12:43 »
I would not, you will find everything under the bonnet getting covered, also you may find it not running right as it is a closed loop system, when mine split the idle was all over the shop.
Offline axewielder
  • 95 dragon 8v
Re: breather pipe
« Reply #2 on: 06 July 2009, 22:38 »
the car should run alright as long as you plug the one to the inlet so there is no vacuum leak, whether the filters get oil everywhere is something i cant commment on, should keep the tb cleaner though :grin:
Offline Len
Re: breather pipe
« Reply #3 on: 07 July 2009, 15:49 »
If its the pipe to the airfilter box you will have to blank that off as you will be drawing in unfiltered air.
www.sas.org.uk
www.the-ace.org.uk
Offline axewielder
  • 95 dragon 8v
Re: breather pipe
« Reply #4 on: 07 July 2009, 21:21 »
1 thats what i sais,2 if he puts one of 'those breather filters' on then it wont be unfiltered  :tongue: :nerd:
Offline wee-golfer
Re: breather pipe
« Reply #5 on: 04 August 2009, 15:31 »
i had a split in mine and i put a breather filter in the top of the engine and on the breather pipe. NO oil at all has come out so far and has worked perfect. i used an oil inhailer to block the induction kit pipe, fitted perfect lol
Offline Andy-H
Re: breather pipe
« Reply #6 on: 04 August 2009, 16:10 »
^^ as above
Replaced with a filter and had no issues to date (touch wood)
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
