Author Topic: Bloody sparkplugs  (Read 1886 times)
Offline james2
  • No scammers please.
Bloody sparkplugs
« on: 04 July 2009, 21:49 »
Just got my new pulstar pulse plugs ,adjusted the gap to 0.8 the same as the plugs that came out ,all was good started and run fine went for a drive to try them 10 min later it lost all power must have been runing on 3 cylinders .Took plugs out to see what was wrong they have got well hot and gone blue, got to send them back now ...NOT HAPPY... :angry:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
Re: Bloody sparkplugs
« Reply #1 on: 04 July 2009, 21:51 »
are these the £100 plugs .......  that give a bhp increase of around 10bhp...?
now drivin a golf 1.9 tdi 90bhp ... time to rack up them miles!! as my daily
Offline DarkGti
« Reply #2 on: 04 July 2009, 22:32 »
well tbh matey ive got them on in mine and they are mint starts really quick and can really feel the differance! must be somthing up with your coil pack! :wink:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 04 July 2009, 23:33 »
from what you state there looks like you could have blown a coil-pack(s)  :huh: ideally vag-com it but if your running on 3 cyls then probably as the efficiency of these plugs which create a better spark need healthy coil-packs i would say and by the sounds of it your no3 was weak then its breaking down and failing
2000 Mkiv GTi 1.8T AGU
Offline Phil18t
« Reply #4 on: 05 July 2009, 22:01 »
darkgti..so they really do make a difference?
Offline DarkGti
« Reply #5 on: 05 July 2009, 23:38 »
yep they really do make a difference the engine seems to run alot smoother and my idel is a little under 1000rpm and not fluxuating! i will tell you in a couple of weeks when i go down my local RR if they make a difference on performace! :grin:
Offline james2
« Reply #6 on: 06 July 2009, 07:14 »
Im getting a refund for the plugs failing ,wont try them again .Iv put the old plugs back in and alls fine . :undecided:
