Author Topic: TYRE PRESSURES  (Read 1268 times)
ianw3321
TYRE PRESSURES
« on: 04 July 2009, 08:45 »
What pressures do you guys suggests for 205/40/17 tyres?
adamrob69
Re: TYRE PRESSURES
« Reply #1 on: 04 July 2009, 09:10 »
it says on the tyre?
Re: TYRE PRESSURES
« Reply #2 on: 04 July 2009, 09:23 »
I ran standard pressures on my 17"s as per handbook and label inside fuel cap.
Offline tweed
Re: TYRE PRESSURES
« Reply #3 on: 04 July 2009, 10:05 »
Also I had to change my two rear tyres. They are 195/55/15 but front are 205/50/15. should I keep the same pressure in the rear as if they where 205/50's
I do know if you fit 195/45/15 you put less pressure than 205/50/15.
Re: TYRE PRESSURES
« Reply #4 on: 04 July 2009, 11:15 »
Yes, same pressure
